Fiat Ducato Fuse (4 Viewers)
Nov 4, 2011
5,948
39,215
Uk
The heater fan on my Hymer based on a 2001 Fiat Ducato has decided to stop working, checked fuse in glove box and now I know why there called fuses, it's melted into a blob and fused! it's self into the fuse box. I've got fuse out now with pliers.
Any idea what could have caused it to get so hot and not blow.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Motor seized, or control rheostat gone t**s up, probably. If you can get to the fan blades, even with a long screwdriver, see if they turn.
Manic
Nov 4, 2011
5,948
39,215
Uk
Checked out fan, turns ok and checked rheostat and that looks ok, no discolouration so I think pappajohn's right with poor contact on fuse.
Now looking for a replacement fuse board because fuse doesn't want to go in now!
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
you should find something here I have not used them for a while but have always had good service from them in the past Link Removed
Manic
Nov 4, 2011
5,948
39,215
Uk
Finally got around to sorting this fault. I used a inline blade fuse carrier and fitted from under the fuse box from feed side of trouble fuse and all working fine now. So I think papajohn was right about loose fuse contector.
Thanks all
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Such good feedback and a successful outcome!
Just the way I think these tech threads should be!
In my experience of automotive electrics, a bad connection is the culprit when it comes to melted plugs and fuse holders. I have come across fuses that have looked suspiciously thick for their claimed ratings as well though!
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Very good!!!!! A sharp and responsive, informative answer!............(From one who never stood a stag).......:rofl:;););)
Jun 30, 2010
7,925
27,239
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Recall by FIAT of Ducattos
May2001-april2002
Chassis# between 6133293- 6227258
Recall# R(2003/027
Something to do with the heater motor that could cause a fire, be worth while checking your chassis#, had mine done, it's free
43,357
49,636
May2001-april2002
Recall# R(2003/027
Cant find that recall but it appears to be this one......
Broken Link Removed
EthnGeoff
263
236
County Durham
Low Profile
April 2009
Cheap, inferior fuses.
Chinese fuses are dangerous and as proved, dont always blow anywhere near their rated amps.
If by any chance it is a quality fuse check the fuse holder in the fusebox for loose contact with the fuse.
A poor contact between blade and holder can cause excessive heat.
Just had a similar problem with the 30 amp fuse in my on board charger. One blade was bent so that whilst it was still making a contact it had not located correctly into the fuse holder, resulting in a melted fuse.
43,357
49,636
Just found out mine is in the recall........fiat dealer saying its deadline for parts etc is 2004 !!
I wouldnt worry too much, if it was going to happen it would have by now.
the recall was in 2003.....12 years and two weeks ago.
it may have been done already.
Recall Launch Date : 05/02/2003
Numbers Involved : 1634
Vehicle Build Start Date : 01/05/2001
Vehicle Build End Date : 30/04/2002
Dec 12, 2010
5,421
21,643
Cumbria
since 2011
Looks like she's already had a visit from the Fiat gremlins PPJ :(
Broken Link Removed
Manic
Nov 4, 2011
5,948
39,215
Uk
How about this for an old thread revival, had a smell today in glove box , checked fuses-non hot, removed fuse board and found this , it’s the fuse holder I had fitted earlier in this thread, I think it’s knackered, good job it didn’t cause a fire.
I think I will need to check fan and resistor when I get back to uk.
