External door handle (1 Viewer)
Oct 23, 2009
784
608
Anglesey North Wales
Adria Twin 640SLB
Since 2010
My Rapido 909Df habitation door has failed again (second time in three years) and will now only open from the inside.
Upon investigation the only thing I can find wrong is a broken 'stud' within the external door handle mechanism itself as shown in the attached picture ( the broken stud is shown with a yellow arrow and the location that its broken away from is shown with the red arrow).
I'm guessing given the flimsy nature of the mechanism that this part is easily obtainable from Rapido and is probably one of their best sellers £££££ but is there anyone in the Uk that supplies the unit to save me some time and probably cost. The second picture I hope gives you the part number info it it looks like its made by FAP Firenze an Italian company .
It would also be interesting to know if this stud has failed for others , I certainly didn't put any undue force on the handle so I can imagine this has happened to a lot of folk.
Feb 13, 2013
994
1,086
Edinburgh
Rapido 881F
Since 2015
Yep ours broke after about 2 years 3 months. Rapido have provided a new one for us (FOC) but I couldn't figure out how to replace the key lock. Rapido should be sorting that out now.
I think it is fatigue problem that you can get with metal castings of dubious quality
wp1234
Oct 23, 2009
784
608
Adria Twin 640SLB
Since 2010
Thanks for this info much appreciated.
Did you go direct to Rapido for a replacement and is it being fitted by a dealer for you ?
Wyn
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
Exactly the same happened on our 890. It simply stopped working on the last day of the Tinsel Rally at Shrewsbury in the heavy snow and cold, but I don’t think that had anything to do with it. I have not tried to fix it myself as it is under warrantee from the dealer. I have it booked in to fix it on 25th Jan. I can let you know what they do after that
wp1234
Oct 23, 2009
784
608
Adria Twin 640SLB
Since 2010
I
Many thanks that would be great
Mr B
992
1,894
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Ours went about 3yrs ago.
Ended up repairing it with liquid metal that we had at work.
It lasted about 3 months. Ended up buying one from a Bailey dealer and modified it to fit. Just put our barrel in and works fine.
Just remember the door handle is left or right, if that makes sense:)
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
How do you get the door handle off? Is it easy enough to do?
Mr B
992
1,894
Yorkshire
Since 2015.......
Yes. If you carefully take the inner panel off. And the closing handle. You will figure out that you can open the door by pressing a certain spot on the mechanism. Lock/unlock using the remote. We had no panel on for a while. :)
D
Deleted member 29692
Highbridge are your best bet. They've helped me out with parts several times.
wp1234
Oct 23, 2009
784
608
Adria Twin 640SLB
Since 2010
Nice job I thought of Aralditing it but given the constant use I didn't think it would last long . First step tmw is to moan to Rapido direct about the quality of the fitting and see if I can get some sort of discount out of them.
Mr B
992
1,894
Yorkshire
Since 2015.......
Let me know how you get on. If the price is right, I’ll buy a spare ;)
Feb 13, 2013
994
1,086
Edinburgh
Rapido 881F
Since 2015
@wp1234 I advised our dealer, Wokingham, when it broke, we were in Spain at the time, a replacement was ordered and sent to us as it had not arrived when we visited them for a self inflicted minor repair.
To replace the lock you need to remove the inner lock, then using a flat piece of metal, I used 1" wide aluminium strip, you need to prise off the facia to the left of the inner handle. Take care, it only held on with plastic friction studs.
Then remove 4 screws that hold the outer lock. Replacement is a a straight reversal of this. I was defeated as I coudn't figure how to remove and refit the key barrel lock. It was freezing cold and I was, as it turns out, coming down with the flu, so abandoned it. As the vehicle if off for an expenses paid trip to the Rapido factory I have asked them to sort it at the same time.
Time will tell!
Mr B
992
1,894
Yorkshire
Since 2015.......
Put a load of handles in your pocket......
You’ll make a fortune:);)
wp1234
Oct 23, 2009
784
608
Adria Twin 640SLB
Since 2010
UPDATE.
I've been in touch with Rapido and fair play although the handle is out of warranty they have agreed to replace and fit FOC, I suspect this is not a one off claim for them . Once I have the new handle I might play around with the old one to see if I can get a working spare out of it - I suspect I will need it in a couple of years time.
Thanks all for the input .
Jan 3, 2017
215
122
Huntly
Frankia i640 SD
Since 2004
After nine months , our door is the same. Under warranty obviously and hopefully not a problem. On some other Facebook page, one chap posted about going to a locksmith to change the way the door mechanism worked and buying new handles from “B&Q maybe” . Sadly cannot find it now.
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
Update. The dealer stripped it down today and informed me that the problem was just as I had told them when I booked it in - ( same stud broke off the back of the door handle as in @wp1234 ’ original post). Naturally they did not have the part in stock so have now ordered it from Rapido and I get to go back in a couple of weeks for them to fit it. It is not covered by the 3 Year Dealer Warrantee which specifically excludes door handles! The part cost is £45, and fitting is 2 hours at Brain Surgeon Rates. I know I could do it myself but I’m going to blow most of my Winter Fuel Allowance on it ( £199 total). That way next time it goes it will by under the guarantee from this repair.
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
Keep the old one and send it over to me to have a look at?
I will try to remember to do that. I also thought I might ask Rapido to send me one like they did @clanjones . Please help me to remember by sending me a pm with your address in about a week.
TheBig1
17,641
43,443
i would drill the arm on the original and use a stainless m4 screw and nut. then add a sleeve on the projecting bolt to match original dimensions. should take 20 minutes and parts under £1
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
I know I should, but if I screw it up it’s a long way to drive with a flapping door to get it out right!
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
Update. Dealer has now fixed it. Cost was £199, complete with 12 months guarantee. I got the broken bit back so will share pictures etc and see how best to rebuild it as a spare. @Stealaway - I’ll be in touch!
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
£199 - whattttttttttttttttttttttttt
I know I should have done it myself. Part was £49. Brain surgeons are expensive.
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
@Stealaway has kindly fixed my door handle be replacing the broken bit with a stainless bolt. So it is ready to fit back into a Rapido door. As I got mine fixed at the dealer, this is now available for anyone else who has the same Rapido Hab Door issue. @Stealaway has kindly offered to swap your broken one for the fixed one, then fix the broken one for the next person. So post on this thread if you have a need
funflair
19,414
30,516
Guisborough
MORELO palace
since 2012
I gave you a "like" but it was to be shared with @Stealaway
Martin
Mr Chrysalis
2,367
319,036
Lincolnshire
Rapido 890F A Class
My door lock has stopped working again. This time the electric motor in the hab door does not operate when when either pressing the remote or internal lock/unlock buttons. The cab door still works though. I can still use the key and the internal handle. So it’s either a wire broken, connection dropped off or a motor failure. I’m still scared of levering off the flimsy plastic inner door to find out so unless someone has a better idea I guess I’ll go back to the dealer again
