My Gaslow's are getting a bit long in the tooth and in the quest for lightness I wondered if these may be a good alternative. Any experience or comments?
GasBank Cylinders
GasBank Cylinders
I think these are Safefill but by another name but they can be installed much the same as Gaslow and the like.Safefill is another option.
If you would like to compare with GasBank, attend the next Woodside Field Rally in April when I know both examples will be on site.
Yep. That was what I was trying and failing to convey. They have a GASLOW style valve system for installed filling.Not so sure about that. Safefill use the same connector for fill and use. Gasbank have a seperate connector for each.
Not for me. I want refillables but if possible lighter than our current twin 11kg Gaslow units.I’m busy checking out Flogas Gaslight bottles in 10kg and 5kg exchange only
We stock the Safefill and the Gasbank type with the separate filler connection .Yep. That was what I was trying and failing to convey. They have a GASLOW style valve system for installed filling.
Thanks.We stock the Safefill and the Gasbank type with the separate filler connection .
Identical cylinder but you are correct about the valve being different.
Ours isn’t branded Gasbank but identical.
nabsim has one on his van
We also stock the Aluminium Augas cylinder which has several advantages over the other two, especially the gauge but also the excess flow valve.
Gaslow 11kg approx 12.4 kg empty, Gasbank approx 5.8 kg.My Gaslow's are getting a bit long in the tooth and in the quest for lightness I wondered if these may be a good alternative. Any experience or comments?
GasBank Cylinders
Thats quite a differenceGaslow 11kg approx 12.4 kg empty, Gasbank approx 5.8 kg.
That kinked pipe hurts my eyes
How much????That kinked pipe hurts my eyes
One of these would look so much more comfortable
MUV W20 Tee Swivel with Lever Changeover
GOK MUV changeover, made with a lever changeover for manual use.autogasshop.co.uk
It only needs the bottles turning out a bit (and the photo would have looked better as well)That kinked pipe hurts my eyes
Not sure what you are looking atIt only needs the bottles turning out a bit (and the photo would have looked better as well)
Not sure what you are looking at View attachment 870938
I am looking at the kink in the red gas pipe as stated in the post I referenced.Not sure what you are looking at
One of these?Not sure what you are looking at View attachment 870938
Yes but be careful as some don’t fit , the centre brass part of the fitting (female side ) can sometimes foul on the regulator so the washer is unable to make a sealOne of these?
NEW W20 Elbow,POSTAGE INC, in UK | eBay
For use with LPG regulators in tight spaces like caravan and boat gas lockers to help prevent hoses kinking and splitting.W20 female nut x W20 male thread. Type : W20 Elbow.www.ebay.co.uk
Seems like overkill having two pigtails anyway. It's not a auto changeover regulator and the supply hose needs to be taken off to refill when empty. Why not just have one pigtail without the T piece with no kink and manually change the pigtail to the full bottle when the primary runs out.Not sure what you are looking at View attachment 870938
It's simply easier to turn off the empty bottle and turn on the full one .Seems like overkill having two pigtails anyway. It's not a auto changeover regulator and the supply hose needs to be taken off to refill when empty. Why not just have one pigtail without the T piece with no kink and manually change the pigtail to the full bottle when the primary runs out.
