engine wont turn off (1 Viewer)
Rapido772f
7
Kings Lynn norfolk
C class
8 years
my fiat 2.8 turbo diesel engine continues to run when i turn off and
take the key out of the ignition any ideas as to whats going wrong?
Sep 10, 2013
1,187
18,750
Chelmsford Essex
Getting better
Check your oil level. Diesel engines can run on if the lube oil can get foamed up and make its way into the combustion chambers, they can race away and blow up.....beware.
andy63
4,672
15,018
south shields
None
since 1990
it sounds like your turbo oil seal may have gone and the engine is continuing to fuel..
which can in extreme cases run away.. is it smoking badly..
Andy
DBK
18,057
48,264
Plympton, Devon
PVC, Murvi Morocco
If it's done a high mileage I suppose it could be burning its own oil, through worn bores or valve stems perhaps? Does it use a lot of oil?
Otherwise, and probably more likely I think, there is a solenoid on the fuel injection pump to shut the fuel off. Which it isn't by the sound of it.
Hopefully, someone with more knowledge of the engine can comment. :)
I assume you can stop the engine by stalling it in a high gear?
May 7, 2016
7,346
11,880
West Sussex
Malibu Van 640 LE K
Since 2003
I had something similar happen on my Renault based motorhome. To cut a long eaxplanation short it was a wiring fault back feeding the circuit that held the injection pump solenoid open. If the more probable explanations already given above don’t work try disconnecting the wire to the solenoid, if it makes no difference it is not an electrical fault.
Reactions: DBK
funflair
19,500
30,984
Guisborough
MORELO palace
since 2012
If its running on oil it should be smoking and a very oily exhaust as well so if its running normally my money would be on the fuel solenoid or whatever controls the pump, our old Merc car engine was controlled by vacuum if you lost vacuum you couldn't stop the motor.
Martin
43,413
50,090
Self fuelling (oil fumes) is extremely rare so I would discount that theory...and when it does happen it invariably revs itself to destruction..which it obviously isn't.
Stuck/faulty cut off solenoid will be the problem.
The solenoid is held open electrically but if jammed can't close when power is removed.
Easiest way to stop it is let it idle in a high gear (4th/5th), clutch down.
Foot hard on brake then let the clutch out quickly...Just dump it, don't let it out slowly.
Feb 9, 2008
4,097
5,931
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I was responsible for a fleet with Volvo truck engines, stop solenoid failure was our No.1 maintenance job, they didn't last a year and were always replaced under warranty. Never had to pay for any of them.
Nov 7, 2015
500
473
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
You may find this information helpful
  1. Originally Posted by Hometune https://www.rac.co.uk/forum/showthread.php?s=aed839bcbb6a61e60dc1f6a27b06b754&p=61966#post61966
    On the top of the high pressure pump on the engine is the fuel shut off valve. It is a solenoid, so that when you switch the ignition on, pulls a plunger out of the fuel pipe and lets fuel go to the engine. When you switch off, a spring forces it shut so cutting off the fuel supply. This is likely to be the faulty part. In an emergency the breakdown people used to remove this unit, take out the spring and plunger and this would always allow the car to start. But the down side is you have to stall the engine to stop it.
    Thanks for your speedy reply, I have been told that my 2.8 JTD is a common rail engine and that it dosn't have a stop solenoid? do you agree with them?
  2. 30-08-10, 19:02#4Hometune
    Formula 1 Driver
    Join Date
    May 2008
    When I looked up your question I checked Autodata first but your engine is not shown in detail. So I looked on my Bosch diagnostic tool and there was a clear picture of the stop solenoid with a description. Your engine has a common rail injection system made by Bosch. If its wrong then Bosch have made the mistake!
Dec 12, 2010
5,448
21,855
Cumbria
since 2011
It probably needs a decoke, my FS1E used to run on once the piston crown was all carbon'd up. :LOL:
Oct 7, 2015
737
3,578
newark
Swift escape 624
Nov 18, 2011
11,863
43,676
Planet Earth
A van
Over 25 year's
Fuel solenoid staying open not uncommon burning oil unlikely as it would destroy it self as previously mentioned
bill
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Our 2.5 engined Ducato does that occasionally, it appears to be a commonish problem, but I have never found a definitive answer.
I have found damaged and loose connectors in the engine bay and replaced all those, but it still happens occasionally. I can either stall it to stop it, or, if I let the engine idle for a few minutes, it will switch off normally.
You should check all the earth connections on the body and engine, ducato’s like to rust , especially where the earth connectors are.
Over the 14 months we have had our van, it has had this problem maybe a dozen times, in about 14000 miles.
D
deleted-member02
I had a similar problem with my old 2.5tdi. Turned out to be a fuel pump / immobiliser issue.
Engine would generally start fine but wouldn't turn off, even with the key removed.
Had to stall it every time, which wasn't ideal, particularly when we had to catch the tunnel home :eek:
Having the pump reconditioned by a diesel specialist solved the problem but wasn't cheap...
43,413
50,090
There's a word I haven't heard for maybe 40 years.
Modern fuels and oils have all but sent that job to the history books.
Same as in the 30s and 40s......
15000 mile and you would be booking in for a rebore.
Today of course, you do more than that between oil changes.
Allanm
5,431
9,192
Since 1987
I have a feeling it’s an immobiliser issue. My alarm has been mostly disconnected. When we bought the van, the alarm had been disabled, the previous owner never had it working and there are no fobs with it. I had a few problems with it setting itself off so disconnected and bypassed everything I could, but I think the fuel pump immobiliser is still in place. I am gradually removing stuff as I find it but have little idea how it is wired into the original loom.
43,413
50,090
The immobiliser stops the solenoid opening and allowing fuel to flow.
As the engine runs but won't stop it isn't the problem....if it was it wouldn't start in the first place.
We still don't know if it's a JTD engine or a TDiD but the latter doesn't have an electric pump, the injector pump doubles as a lift pump and is purely mechanical.
Feb 24, 2013
13,133
101,665
Bolsover, Derbyshire
Hymer S800
not long enough
I am now presuming this wasn't maybe as serous an issue as it sounded, or it was extremely serious :(
OP hasn't been back on here since one minute after posting this thread
It has got me wondering what I would do though, I have an auto and no idea where my fuel pump fuse is, it was raised on another thread about being a good security addition
May 7, 2017
1,974
2,296
Suffolk
2017 Chausson 718XLB 180
20 years
you could spend a lot of money changing this that and the other, if you are not professional enough take it to a diesel/electrical expert workshop. Don't guess.
Tony A.
Reactions: DBK
43,413
50,090
Annoying isn't it.
A member poses what appears an urgent question then doesn't have the decency to check for replies, let alone acknowledge them.
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
Come on, he only posted 24 hours ago, and he didn’t make any claims about it being urgent. Didn’t look urgent to me. Not everyone logs on every 5 minutes.
It’s good that when you post on this forum you can expect several good answers within a few minutes (plus the usual uninformed guesses), but please don’t castigate people for not coming back immediately with a follow-up. There are all kinds of reasons for someone not coming back for a few days.
Feb 21, 2016
4,929
29,974
Uk
C class
Since 2017
Of course he’ll come back,he’s a Rapido owner. They are all jolly decent folk,impeccably well mannered,the best of the best!:D:D;);)
Feb 24, 2013
13,133
101,665
Hymer S800
not long enough
I have just spotted he has only made 4 posts, but really odd to post then go the same minute
I did read it as urgent, I really thought he was sat somewhere with the engine running and didn't know what to do
43,413
50,090
Agreed, re: not logging in, but being a member for the last five years they know replies on this forum, unlike many others, will be almost instant and as the question was asked its only reasonable to expect the op was waiting for a response and to regularly check for replies.
Not being able to turn off the engine seems pretty urgent to me....some folks wouldn't even think of stalling it.
