Ahh well, that is naughty and after he's gone some other person ends up looking guilty if they park there.It was in the caravan area. No hgv there.
... and until such time as they are fined several pence per litre for raw sewage and a slightly lower rathe per litre of semi-treated sewage, they will continue to dump.Why the hell worry about a bit of soapy water when water companies dump untreated sewage into rivers and the sea legally
I totally agree. Some people think the death sentence should be appled to irresponsible grey water discharge. Drive a smoky diesel motorhome poluting the environment- good, drop some soapy water bad (i assume these people have found ways of cleaning their vehicles without allowing any dirty soapy water touching the ground )Why the hell worry about a bit of soapy water when water companies dump untreated sewage into rivers and the sea legally
YesIf we had a water shortage, would you use your grey water if you could collect it to water your garden?
Well I (and all my neighbours) am the 1% where surface water, rainwater, sinks and toilet water all goes down the same drain. How do I know? If I lift the drain cover in my yard I can watch it all pass down the gully. I have had my drains lined due to root ingress from the trees in the pavement and seen the pipework enter the gully in the road beside my house. This of course is useful because i can also remove the drain cover to empty my cassette when i return form a moho trip. I then flush the loo in the house and watch this water flow to check that the casette contents have been washed down.99% certain you are wrong there
Surface water drains are very rarely connected to foul sewers
Actually combined drains are quite common in town and city areas, I come across them all the time. Is the drain by your kitchen a gulley which has the sink wastes running to it? If so it should be running into the sewer as you can’t run sink wastes to surface water systems.
Some towns still have combined systems David.99% certain you are wrong there
I have done the same thing ad you many times. And it won't affect anything. It seems a trivial thing really compared to pulling into laybys that are frequented by truckers and bottles of piss and human shit all over.Ive dropped my grey plenty times at grids at the side of the road.
I always make sure I do it on a grid where my van leans properly to get it all out .
A bit of dishwater and shower water gong down a roadside kerb grid wont kill anyone.
Me thinks a few people here are telling porkies
Maybe they were former employees at No 10 !Ive dropped my grey plenty times at grids at the side of the road.
But you are happy with the stink of stale urine, which in my experience is ever present in service areas, especially where trucks park up!!!Maybe you don't worry about it but I drive through that area several times a week and I don't want the stink of their body washings or washing up thanks
grease mainlyCan someone explain why grey water should be put down a drain? I've absolutely no problem at all washing my van/car/whatever in the road and letting the grey water go wherever it wants.
Theoretically it is illegal under environmental regulations just that they were too frightened to actually enforce it. & Basically why all fuel stations have to have there own drainage around the pump area & if they have washing facilities it all has to be recycled with no external outflow.Can someone explain why grey water should be put down a drain? I've absolutely no problem at all washing my van/car/whatever in the road and letting the grey water go wherever it wants.
It depends where it goes after the gulley really, there is a surface water culvert runs under the road and then a few housing up from us the culvert then turns into an open watercourse through our garden so possibly it does affect somebody/something, it is even worse though when the foul finds it's way into the surface water gulley due to antiquated pipesI have done the same thing ad you many times. And it won't affect anything. It seems a trivial thing really compared to pulling into laybys that are frequented by truckers and bottles of piss and human shit all over.
Why would they? They shit in it so they can't talkThe fish. ducks. geese, swans. herons coots. etc don't seem to mind.
Almost correct, fuel stations have interceptors to catch spillage that get emptied by vac tankers on a regular basis. They still discharge to public sewer.Theoretically it is illegal under environmental regulations just that they were too frightened to actually enforce it. & Basically why all fuel stations have to have there own drainage around the pump area & if they have washing facilities it all has to be recycled with no external outflow.
Always been totally illegal here in spain to wash a vehicle anywhere except at a designated vehicle washing facility. Even illegal on your own property.
I was not trying to play down that emptying grey waste anywhere is OK but in certain circumstances it would be OK. Its not so much antiquated pipes that allow sewerage into surface water systems but illegal sewer connections that have caused this there are hundreds all over Lincs so there must be thousands all over the country.It depends where it goes after the gulley really, there is a surface water culvert runs under the road and then a few housing up from us the culvert then turns into an open watercourse through our garden so possibly it does affect somebody/something, it is even worse though when the foul finds it's way into the surface water gulley due to antiquated pipes
Yes. And your point about someone dumping it in a service area is?If we had a water shortage, would you use your grey water if you could collect it to water your garden?
As I have pointed out. This is a separate caravan area, no trucks. Pity the poor vanners that pull in for lunch and have to endure the stink from the grey waste dumped there.But you are happy with the stink of stale urine, which in my experience is ever present in service areas, especially where trucks park up!!!
Yes I certainly get the illegal connection issue, our particular issue has been investigated by the water authority and their conclusion was something like a foul interceptor block/overflows and can then find it's way into the adjacent surface water culvert and then our garden, when we get heavy rain it runs black as all the muck washes off the roads, thes rest of the time it's quite a pleasant little featureI was not trying to play down that emptying grey waste anywhere is OK but in certain circumstances it would be OK. Its not so much antiquated pipes that allow sewerage into surface water systems but illegal sewer connections that have caused this there are hundreds all over Lincs so there must be thousands all over the country.
Yep !If we had a water shortage, would you use your grey water if you could collect it to water your garden?
Where did I say I was happy with the stink of urine please?But you are happy with the stink of stale urine, which in my experience is ever present in service areas, especially where trucks park up!!!
same with me, if we have real downpours for days, or blockage down the road we get our drains backing up for about 10 houses down the street,where then it cuts off into the park underground and goes off and as we are the final one in the chain it comes out of our grids etc. Toilet paper remnats and the lot.Yes I certainly get the illegal connection issue, our particular issue has been investigated by the water authority and their conclusion was something like a foul interceptor block/overflows and can then find it's way into the adjacent surface water culvert and then our garden, when we get heavy rain it runs black as all the muck washes off the roads, thes rest of the time it's quite a pleasant little feature
There is a skill involved in selecting the right layby on the right side of the road for the waste to go directly down the drain and leave no evidence of dumping less water than is used to wash the van.Ive dropped my grey plenty times at grids at the side of the road.
nd then there's those filthy canal boats where the grey water goes directly into the canal. The fish. ducks. geese, swans. herons coots. etc don't seem to mind.
