Eline frost stat. (1 Viewer)
Oct 15, 2011
4,190
11,390
Not Glasgow
Carthago chic eline
Since 2011
I’m trying to find the frost stat while I’m still in sunny Spain rather than when I’m back in Scotland, I’m sure I found it before but I’ve searched everywhere and even perused the manual. It’s an I50 model that I have.
Lenny HB
53,698
150,988
On the coast in West Sussex
Hymer B678 DL
Do you mean the dump valve for the hot water, if so you will have trouble as I don't think it has one.
Lenny HB
53,698
150,988
Hymer B678 DL
Just checked with my mate, no frost stat just a manual drain valve.
I beleive the reason is you can't run the heating on an Alde without water in the boiler.
WESTY66
5,900
14,434
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Im sure you can Lenny, I’ll have to check now I’m doubting myself but I was sure you could.
I think the dump is in the boiler👍
Dec 13, 2019
2,714
2,178
Northumberland
Hymer A Class
Since 2019
I would also be interested to find out. I have drained the water system, and turned the pump and boiiler off. However, I have left the heater on at 8% as a frost protection. System is Alde.
WESTY66
5,900
14,434
South Yorkshire
The heating circuit is independent of the water circuit, so it should be fine👍
WESTY66
5,900
14,434
South Yorkshire
BnBJwf Sorry just re read your post, you haven’t turned off the Alde completely at the panel have you? Did you mean you have turned off the water “cheese” and put the heating to 8 deg?
Dec 13, 2019
2,714
2,178
Northumberland
Hymer A Class
Since 2019
No, the panel is still on. The boiler is turned off. The heating is turned on with the temperature set to 8⁰C.
Many thanks for your message.
Lenny HB
53,698
150,988
Hymer B678 DL
I checked with my mate he has an E Line and he reckoned you get all sorts of problems if you run the heating without water in the tank and it's best avoided, his van is 2018.
Dec 13, 2019
2,714
2,178
Northumberland
Hymer A Class
Since 2019
In fairness, if I have the water charged, the thing shouldn't freeze up anyway as the MH should stay at 8⁰C?
Thanks for the warning.
WESTY66
5,900
14,434
South Yorkshire
I can’t see how Lenny (not doubting your mate) the circuits are totally independent of one another, I’ve remembered I’ve run the heating in mine without water for the last two winters now (always drained the water off) and never had any problems👍
That’s what I like about this van, everything works as it should! Sure I’m always looking, I even ordered a new van at one point (but couldn’t see the order through) but when I get back in this van everything is “just right”👍👍
