Electrics and Battery charging conundrum (1 Viewer)
gazza280
97
355
Worthing
Advice needed please.
My camper conversion (I use the words loosely) When connected to hook up I can use power points for tv etc but the hook up will not charge my vans starter battery. Could somebody tell me if there is a charger that can be put on the system to charge the vans battery when connected to hookup and alternatively a way I can charge leisure battery when driving from site to site.
I know in a Motorhome there is a zig unit and such like but this is a small scale camper conversion and the electrics were done previously by someone else.
Please bear in mind I am completely stumped when it comes to electrics. Though it would be comforting to know that when I'm hooked up I can still drive away with a charged battery and when I'm driving I don't need to worry that the leisure battery has no charge.
Many thanks in advance
Gary
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
you could add a suitable zig unit that incorporates a charger and fit a split charge relay for the leisure battery, however the simple way would be to just hardwire in a 4 stage charger, as in cheapo from Lidl and plug it into a spare socket so that it will charge when power is applied. If you are unsure about electrics then you will have to rely on someone to do it all for you.
Jan 28, 2008
10,123
18,394
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
any charger can be wired to you 240 electrics and your battery best to get one that is smart or intelegent chargers that will go to float charge when the battery is full or you can get a power supply from a caravan
Search on ebay for
Caravan charger
Battery Master - other makes available.
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
charging your leisure battery whilst travelling is easy see here for all you will need
you shouldn't really need to charge your vehicle battery as all the 12v power you use should be from the leisure battery but there is no reason you couldn't just plug in a standard battery charger and connect it to your vehicle ,or just have a good charger with several isolated outputs so as to charge your vehicle battery and the leisure battery seperately via the one charger look at sterling power products or waeco perfect power chargers both good quality manufacturers
kevin
11
essex
coach built
2nd year
isolator
can any one tell me if this is normal the 12v isolator switch was turned off so there were no 12v in the habitation area when engine is started i have 12v working in habitation even when isolator is turned off
Feb 27, 2011
14,762
76,271
I have a self build also. I used the 25Amp version of this
http://www.amperorassociates.co.uk/Category/c-battery_chargers.html
It has been working fine for 3 years now on my 500Ah battery bank.
Just needs connecting to the battery and mains. Nothing complicated. However I would recommend a fuse at each end of the 12V cable as close to the battery and as close to the charger as possible.
43,357
49,636
if i understand correctly what you wrote then you already have engine to leisure battery charging.via a split charge relay under the bonnet.
basically when you start the engine the relay connects the engine and leisure batteries together so charging both but someone has connected the "charging" wire to the wrong side of the isolater switch so the power is going to the hab 12v instead of to the leisure battery so it wont be charging the battery unless you leave the isolator switch turned on when driving.
oldun
747
162
St Neots
VW Campervan
Since 2001
It seems to be UK law that the 12V hab sockets, lights etc (not the fridge) must be turned off when the engine is started. Not sure why.
43,357
49,636
It is nothing more than a National Caravan Council regulation which is not enforcible in law.
Many, if not all, foriegn manufacturers wire their vans to provide 12v to the hab area even with the engine running.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
and there was me thinking the habitation battery was the leisure battery, hee hee
Babs13
4
Fiat Ducato Sonata
Could someone tell me where my split charger would be and what it would look like please. I have a 1997 conversion by Holdsworth on a Fiat Ducato. I do have a Zig unit in the back of the van with 2 relays and I find one relay is getting hot when the engine has been run, could this be the split charger.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
For anyone interested, linked is the EMC directive, relevant to this issue,which is enforced by the VCA, a division of the Department for Transport:
http://www.conformance.co.uk/adirectives/doku.php?id=autoemc
Presumably, isolating the 12V installation in M/Hs precludes the requirement to comply with the directive, in respect of all equipment served by the circuits of the installation. An alternative solution, for compliance, would be to test everything!!
FULL TIMER
795
717
NORWICH
It is a possibility, from memory one relay would be for the fridge 12v supply whilst driving the other for charging the leisure battery,
Babs13
4
Fiat Ducato Sonata
Thank you I think you may be right, I think I need to change the one that is getting hot as it may be something to do with the charging from the engine battery to leisure battery. Could this be the split charger do you think.
17,639
43,424
yes that is what a split charge relay does. if one is getting hot, it has failed. not expensive though
