Electrical problems Pilote G740C 2018 (1 Viewer)
mika
5
pilote g740 2018
Hi,
Sorry my english, I Hope you will understand me !
I have many electricals problem in my G740C 2018 :
- Door of cell : central locking don’t Word
> contact and cables ok
> contact door ok
- Fridge : don’t work on 12V when engine is running
- Running board « Thule » don’t close automatically when engine is running (but work with control panel)
All fuses are ok in the cell and under the engine hood.
I’m lost ! Do you havé an idea ?
Oct 26, 2014
1,873
3,206
Dumfries and Galloway
Pilote P696GJ
Hi,
> contact door ok
Mika if you are on Facebook there is a Pilote owners page where you’ll find a lot of advice and help
There are many members on the forum from all over Europe
Jan 20, 2019
844
1,858
Bristol
Pilote G740
Since 2019
Are these new issues or have you just bought the van and it has these problems?
We had similar electrical issues on our 2017 740 we bought about a year ago. In the end called out an auto electrical engineer who discovered that the van had never been wired correctly from new. All problems fixed and thankfully it didn’t cost too much!
M
mika
5
pilote g740 2018
No everything rien correctly before this week.
M
mika
5
pilote g740 2018
Worked sorry
Oct 10, 2018
1,997
1,127
Bracklesham Bay, West Sussex
PVC
The D+ signal from the alternator output may be missing, check near the starter battery for a 2 amp fuse (which may be near a 20 amp fuse).
There also could be a separate Schaudt fuse/relay (PLT02 ?) module near the EBL that has these fuses within it.
M
mika
5
pilote g740 2018
Hi thank you for these informations PLT02 is tested and ok, 2A and 20A fuses are ok too. And you are saying there is another fuse near the battery of the truck ?
Oct 10, 2018
1,997
1,127
PVC
I do not know of other fuses if they are already at the PLT02 , but it may be worth checking at the starter battery area anyway.
There is a Fiat Ducato converters manual in the Resources section on the top blue line of this page that you can download , it is on page 4 of Manuals for Motorhome stuff and it has details of the Coach builders connection socket and its location that may be worth checking in it at section 3.14 of the manual as it could relate to your problem.
You may find this connection point behind a panel at the bottom of the right hand cab door pillar.
Tombola
4,837
15,724
Merseyside
Rapido 8094DF
Since 2004
find the relay that closes the step, this will probably control the fridge too, wire it across to test and then replace if faulty
3,619
7,789
Milton Keynes, UK
Burstner Lyseo 727G
19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
The step and the fridge not working do sound like the D+ signal not being present. This should be related to the engine battery. Have a look for a low amp fuse near the engine battery ( 1 or 2 amp)
I cannot see the central locking being related to this.
