Electric hotplate query (1 Viewer)
May 24, 2014
654
2,564
North Devon
Autosleeper Kingham
Since 2013
We want to purchase a small hotplate to cook on or to boil some water as backup to the existing gas cooker on our As Kingham. We have our eyes on a 1500w hotplate and would like to know if this can be run on hookup?
Dec 10, 2013
3,426
12,364
South Staffs
Pilote P740GJ
Since 2013
If we are on EHU we us a 3100 twin induction hob with no problems as long as I turn the the heating and water heater off.
That is on a 16 amp EHU but a lot of sites are not that generous.
Dec 10, 2013
3,426
12,364
South Staffs
Pilote P740GJ
Since 2013
10amp yes depending what else is using mains.
16amp yes.
6amp no
1500 watts is 6.52 amps at 230v
Sorry John, I miss read your post. I see now you were talking about the EHU power and not the consumer item.
Note to self, pay more attention. (y)
43,392
49,874
I think John means 16 amp no
6 amp yes. :)
1500 watts is
How do you work that?
1500watts is 6. 52 amps which isn't going to work on a 6 amp supply but will work on 10 and 16 amp supply so
10 yes,
16 yes
6 no.
Oopps.... Just seen you post above this one. Sorry.
Note to self...... SPECSAVERS!! !!
mikebeaches
5,407
8,637
Bristol
Rapido V68 Van Conversion
Since 2009
If you buy a 1,000 watt one instead, you'll be fine on a 6 amp hookup, providing you're not boiling the electric kettle at the same time... ;) (y)
One on Amazon for £16.50 with free delivery. Link here: https://tinyurl.com/y9afts42
We've got 2 stand alone hobs, and one is only 500 watts, which is a bit slow, but we can use it anywhere. The other is 1,500 watts, I think, so have to be very careful where we use it, especially on the continent. (y)
Minxy
32,700
66,738
E Yorks
Carthago Compactline
I'd stick to 1000w max as that will allow you to use it on more lower amperage sites and also not have to worry about turning off any other kit to do so, however, if you are on sites where you're having to pay for electric why not consider a suitcase gas stove instead - they are very good, with a very adjustable low to high output, canisters are cheap and can be got anywhere, even in Europe, plus you can take it with you to the beach etc if you want. We have one and wouldn't be without it.
mikebeaches
5,407
8,637
Bristol
Since 2009
Yep, we also carry the small 'suitcase' gas portable, which we often use for cooking outside the van - especially fish! ;) (y)
And as an emergency back-up, just in case anything goes wrong with the main gas supply.
TCG
Jul 6, 2017
1,367
2,051
Salford Priors
Autotrail Delaware
Why not buy a portable induction hob, with variable power
Appliance direct £27
Dec 10, 2013
3,426
12,364
South Staffs
Pilote P740GJ
Since 2013
I am not sure induction hobs are variable power, although they have different heat settings I think it uses full power to get to that temperature.
Someone may be along soon who knows what they are talking about.:D
Mar 8, 2016
725
1,577
Lancashire
PVC
Since 2009
I seem to remember the instruction book with mine told me how much power each setting used. It’s an induction hob from Aldi. Will have a look tomorrow as seem to recall a handy table but put instructions somewhere safe so will need to find them.
Mar 23, 2012
9,587
32,259
sleights
c class
Just remember to turn off the electric water heater unless you add it in the calculations
TCG
Jul 6, 2017
1,367
2,051
Salford Priors
Autotrail Delaware
i use ours in france on 6amp hook up no problem, with other electrical items running as well. variable power from 400 to 2000
