Drunken TV Bracket (1 Viewer)
Apr 12, 2021
206
84
Next to The Rusty Angel
Race Van
Does anyone have a remedy for the TV bracket leaning down with the weight of the TV. It is leaning to one side. When I lift the TV horizontal there seems to be play in the extendable bracket allowing it to lean. Would it be a case of purchasing a new one or has anyone done a mod to rectify this?
TA Steve
20230201_124058_resized.jpg 20230201_124103_resized.jpg 20230201_124117_resized.jpg
Apr 20, 2020
1,088
2,386
Northern Ireland.
Adria Compact SC.
Since 2017
They are not a great bracket to be honest.
I was forever tightening ours and as you say if you tighten it too much it wont move.
Probably better to replace it with something more substantial.
Jan 25, 2022
358
2,255
Elddis
Changed the nuts on mine for ones with nylon inserts, e-bay I think.
I also cut a disk (from the material with holes in you use to stop things skipping around) and put it under the main centre nut to stop it spinning.
1,124
1,123
Sutton Coldfield but East Yorkshire man at heart
Elddis Autoquest155
Since 2018
TA Steve
View attachment 712238 View attachment 712239 View attachment 712240
What is the bracket material, Plastic or metal? former material tends to flex. Also have you checked the weight of the tV against the bracket load specification? Also does the wooden material to which it is bolted flex?
May 21, 2021
178
462
Cambridgeshire, UK
Auto Sleeper
Since 1986
I’ve had problems like this before, in the end I purchased a shorter one (just two arms), there’s no thought whatsoever go into the design when these are churned out by our Chinese friends,
The problem is they are great until you hang a telly on the end, they need to be so much more robust.
I found that the majority of these 3 arm ones are just not upto the job, Rubbish for want of a better word.
Sep 17, 2017
5,571
10,413
Birmingham, UK
A-Class
Ours was similar. But there was rotation available at the TV end, so I could compensate for the droop.
Never watched the TV and it rattled around, so I took it out.
Sep 25, 2023
684
851
Swift Sundance 590RS
I would say that is too much for the wooden panel unless there is a metal plate or big washers behind the wooden panel. 4KG TV hanging 1M from the wall with only approx 150mm fixing, equates to about 13KG on each of the top screws. The bottom screws do nothing they just act as a pivot point. The middle screw reduce that somewhat but still a lot at the top screws. And you never get the droop out of those arms.
Mar 14, 2019
1,124
1,123
Elddis Autoquest155
Since 2018
Mar 14, 2019
1,124
1,123
Elddis Autoquest155
Since 2018
Too many joint which all droop unfit load
Feb 5, 2020
2,391
89,592
Crosby
Smileo 202
Was a Newbie but getting the hang of it now.
We have one and it looks like the middle pivot bolt has a slight bend in it - will one day🤞 get round to sorting a chrome Vad bolt to replace.
For now we are helping to support it with a bungee cord attached to the drop down bed safety net D ring.
