Drain down (1 Viewer)
Apr 12, 2019
43
32
Midlothian
Elddis encore 250
6 years Motorhome 15 years caravaning
Evening funsters will be going at the weekend to drain down the van
only had it since June from new and wondering if anyone knows exactly where the drain valve for the water system is
had a quick look under the bed as the book says it’s there but I am sure you guys will be much better with a precise location
many thanks in advance
PP Bear
7,852
28,996
Kent, UK
Auto Trail Dakota SE
This is the style on my van.
Depends on make and model, which would help.
K
Apr 12, 2019
43
32
Midlothian
Elddis encore 250
Sorry it’s at 21 plate elddis encore 250 with fixed. Double bed were the pump etc are underneath the bed
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
Not sure what you are trying to drain down- you have Alde heating do you not?
Fresh water and Grey water is on side of van on offside
Heating is sealed and should have anti freeze
K
Apr 12, 2019
43
32
Midlothian
Elddis encore 250
Not made myself clear 🤔 duh
It’s just to drain the water from taps etc for winter thanks I think I remember seeing something near the boiler the looks like a tap
K
Apr 12, 2019
43
32
Midlothian
Elddis encore 250
Thanks drove out to check it out it’s the same as the one in the photo from pp bear
Is that in the closed position ? Ie working normal
Or drain position 👍
PP Bear
7,852
28,996
Kent, UK
It’s illustrated in the drain position, dropped down is closed, up is open and will drain down the boiler.
