- Feb 24, 2013
- 13,089
- 101,499
- Hymer S800
- not long enough
Morning all
I might actually have got very lucky and fixed this myself, but not confident
This is the back of our fridge, not that you can see much
I believe the first one shows the burner behind the plate (slightly bent due to me trying to see inside ) the second I think is the gas valve I have seen mentioned on other threads
Arrived on site yesterday, no hook up, after the initial delay when turning off the ignition we got an alarm from the fridge, flashing triangle and gas symbol
We could smell gas (slightly) so fairly happy gas getting to burner, could hear it clicking so happy it had power. Pressed triangle to try again, creates a few minutes delay before alarm comes back , tried this about 10 times then turned it off for the night
Read a few threads on here and got up more confident this morning, turned fridge on, went straight to alert, no delay no thinking about it just flashing and beeping
So took what was left of my refreshed confidence out into awning (yes that’s all working very well and safari room back up ) took grill off, gave it a hard stare, identified above components, turned fridge on, could smell a whiff of gas and hear / see the igniter sparking, (withdrew head ) alarm back on, turned fridge off
Gave what I think is the valve a very gentle tap, gave the burner area a couple of lungs fulls of my best morning breath , turned fridge back on , bingo it lit
I don’t have much confidence in it relighting when it should, but for now it will be on for a while cooling the fridge I would expect
Thinking I might just have got very lucky and blown something away from the critical burny bit
