Dog Cooling Coat - First Impressions (1 Viewer)
DBK
18,049
48,223
Plympton, Devon
PVC, Murvi Morocco
It's 38C at the moment and our Charlie is feeling the heat. He has a cooling mat but it feels hot. I put him under a tap earlier but he soon dried. So I dug out his dog cooling coat. I tried it earlier on a walk in Corsica and it seemed to work well and didn't seem to bother him at all.
It's called a Prestige dog cooling coat but other makes do similar things. It is made out of a thick material which absorbs a lot of water. When it is dry it is rigid so you have to remember to fold it while it is still wet. :) You could wet it under a running tap but a small bucket is better.
Then fit to dog.
It works by the evaporating water cooling the contents of the coat. :) The walk on Corsica was about an hour and the coat was still wet at the end but once wet it is easily re-wetted from a bottle of water.
The drawback with it is being wet it isn't particularly practical inside the van but outside it works fine. Recommended for your hot dogs.
Jan 12, 2016
300
2,063
Amble
adria izola
since 2014
Used a similar coat on our boxer last year ,works great and does not seem to bother her.
  • Thanks
Reactions: DBK
Ven
Aug 15, 2008
1,501
70,414
East Sussex and beyond
Since 2009
We have similar for Misty, being a dachshund she is a sun worshipper and rarely warms to even panting stage in 30° plus but we used it once when is was 40° and it definitely worked.
The only problem is the one I ordered probably would have fitted a Labrador so I had to “adjust” and it now looks like something Frankenstein might have created :( It will still do the job though.
  • Thanks
Reactions: DBK
champers
4,227
8,602
Skegness, UK
Frankia i650 FD
Since March 09
Please read up on these cool coats that have to be kept wet
I purchased one of the better cooling coats at a show last year £30:for chihuahua size
It had to be kept damp in their bag when stored..
I have since learned through dog groups that if left on the dog for longish spells they can get lung / pneumonia problems ..
I had in stock already a cheap B&M one which is great .for my chihuahua doesn't smell ....ps the expensive one stinks of mold so threw it out it was horrid
Just be aware folks xxx
(y)(y)
Langtoftlad
8,874
151,712
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
Think I might be trying Kerry's for the first time this weekend at Bodiam, if the forecast is to be believed... she's got one of those cool mats too, but she doesn't like it, the plastic is too slippery for her...
DBK
DBK
18,049
48,223
Plympton, Devon
PVC, Murvi Morocco
(y)(y)
Ours doesn't have to be stored wet - I can't think of a better way to turn it mouldy. :)
Not sure about the lung problems, the coat is well away from his muzzle so he isn't going to be breathing in damp air. Sounds like a scare story but he will only be wearing it for a few hours at most.
He's now sleeping comfortably - and yes, another drawback, don't let them roll in the dirt!
Shrimp
May 27, 2015
3,999
33,741
Bedfordshire, UK
Hymer B584
Long time
I have one for our JRT but haven’t used it for a while, she hates having any kind of coat/clothing/harness on so we just soak her regularly. But a paddle or a swim works well for her!
  • Thanks
Reactions: DBK
Ven
Aug 15, 2008
1,501
70,414
Since 2009
Ours doesn’t have to be kept wet (it was cheap :giggle: ), it’s just mesh really. I would only use it when heat exhaustion is a worry - when we reached 44° she had it on for a few hours but it needed dampening fairly regularly at that heat.
  • Thanks
Reactions: DBK
TheBig1
17,653
43,494
ridiculous idea to keep it stored damp, as mould spores will grow. Use it for a couple of days and wash it and dry before reusing
Welsh girl
3,658
3,036
Globecar
Since 2004
Li used one for my Yorkshire terrorist Susie, i think she appreciated it. Kept her really cool, she used to suffer a lot with the heat.
Dec 16, 2017
1,231
2,517
Almuñécar, Spain
Low Profile - Globebus T7
I'm not convinced they work. A dog's fur is such a good insulator I'm not sure the temperature drop caused by evaporation will actually do much to the temperature of the dog's cappiliaries under the surface of the skin. Their primary method of temperature regulation is via panting, as unlike us they don't have skin sweat glands to evaporate sweat off in order to cool. Would be interested to see if anyone has ever actually done a proper evaluation of these jackets. You haven't got a thin thermo sensor, DBK, you could slide under a dry coat but next to the skin under the fur, then a wetted one by any chance?
  • Thanks
Reactions: DBK
Jan 12, 2016
300
2,063
Amble
adria izola
since 2014
The only problem is some people think you are being cruel putting a coat on a dog when it is hot. Takes some explaining with a language barrier.
  • Thanks
Reactions: DBK
champers
4,227
8,602
Skegness, UK
Frankia i650 FD
Since March 09
Info was from 2 vets I spoke with regarding these and from other dog groups ... maybe I haven't used the correct terminology....just advising not to over use too long ..
Kath
TheBig1
17,653
43,494
Oh it does work.....we use it as first aid for dogs with heat exhaustion or heatstroke using a wet towel
  • Thanks
Reactions: DBK
Langtoftlad
8,874
151,712
Since 2015
This is true, however Kerry gets hot when it's hot, cold when it's cold... so I anticipate that a cooling jacket effectively acts as sweating & evaporative cooling in a way their bodies cannot...
It prevents their internal body temp from rising to an uncontrollable level.
bigtwin
5,266
9,983
Derby
Concorde
Since 2006
They certainly work for our boxer (the brand is Cool Coat):
313835
It certainly reduces the extent of his panting.
I too thought that this was strange but, we have left ours for some months with no ill effects (mould or smells).
Ian
RogerThat
1,128
991
North West
PVC
Interesting thread...
It's only been 24C these last few days but my poor girl is really suffering in her double fur coat.
I was wondering if someone made a paper thin foil dog coat, like you see the marathon runners wearing, I thought that might just reflect the heat away in the first place?
I can't get my head around wrapping her up in a thick wet coat/blanket. Yet I was talking to someone only yesterday who also swears by them for his Collie!
  • Thanks
Reactions: DBK
Ven
Aug 15, 2008
1,501
70,414
Since 2009
My coat is actually very thin, almost like a thin airtex if you know what I mean so as long as it’s soaked and wrung out, it definitely cools them down rather than making them hotter.
DBK
DBK
18,049
48,223
Plympton, Devon
PVC, Murvi Morocco
I can only say after fitting the coat Charlie stopped panting after about 5 or 10 minutes. Dogs react to the ambient temperature so when that cools because of the coat around their body they feel cooler.
Sep 3, 2009
1,532
6,286
NW Surrey
LHD Hymer exsis-i
We've always used a plant spray bottle which gives out a very fine spray. I think it has the same effect without making the dogs coat saturated, and we can spray that face and bottom of their pads as well. We can use it on humans as well! We got the idea years ago from the outdoor mist showers they had (have) on the A61/A62 motorways in the south of France. The idea was that you walk through fully clothed and evaporation cooled you down without soaking your clothes. They rally worked.
Malcolm
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
I'm a newbie and always will be. You never know it all.
I've found that if I throw a couple of buckets of water over the roof of my swift the dog Is luvverly and cool inside.......no idea why:unsure::imoutahere:
  • Thanks
Reactions: DBK
Sep 28, 2015
2,034
2,634
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
I can’t work out the logic in putting a coat on if it’s too hot in an attempt to keep cool. How can trapping air result in lowering temperature?
We’ve considered one of these but never been easily won over by sales talk.
We ensure our Cocker is regularly brushed and then her natural coat kept wet.
  • Thanks
Reactions: DBK
DBK
DBK
18,049
48,223
Plympton, Devon
PVC, Murvi Morocco
They keep the dog cool using the same mechanism humans keep cool by sweating. In order for our sweat to evaporate it needs energy which it obtains by drawing heat from the body. The water on the wet coat evaporates the same way, cooling the dog. You can get terraccota wine coolers which when soaked cool the wine inside as the water evaporates.
The real test is to try one, the dog coat that is, not the wine cooler, they work but we only use it when essential. Going somewhere cooler is the best solution and we are doing this tomorrow. :)
