DIY through the roof WiFi in pictures (2 Viewers)
Jun 6, 2012
1,143
1,550
Leeds
I'd go to £25 if I'm collecting or £30 if you're dropping it off?
Ok £25 to collect. I'll be around tomorrow morning or I can leave it at my parents if tomorrow morning not convenient, let me know and I'll pm you details.
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yup great (y) I'll collect straight after rush hour as we're going off for the weekend.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
In all the time I've come to Hebden Bridge CC I've never managed free internet UNTIL NOW ! :D
I used all my monthly allowance last weekend :( but not anymore (y)
Thank you David for the mint condition spare aerial
May 29, 2013
2,608
19,335
Tyneside
Chausson best of Flash 10
Several years now
Look up the pole behind the van............................free electricity !!!
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
In line with my continuous improvement methodology (y)
My MKII is prepared in a silver livery with a longer pole and now just awaits a 1.8 metre USB cable instead of the 5 metre. The enclosure is now solvent welded to the pole to negate the need for industrial looking cable ties.
Having experimented last week with expanding foam this will be injected after cable installation.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
At first I thought that was a clever response but when I explained to wifey I creased myself larrrfing :LOL:
Feb 9, 2008
8,954
18,710
Corby, Northants
Coach Built
I have one of these too. Are you in a position to compare with the latest Antenna sold by Adam ? I'm thinking of upgrading but do not see the point unless the improvement is significant.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I doubt there is any difference. To me the new ones are a result of ours being discontinued rather than superseded
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'm now parked right under a Vodafone mast (not relevant) on a CL "The old packing station" This is the fourth location on the trot that I have found a useable FON connection. The additional height without obstacles is certainly the way to go. Currently have a 39mbs BT Fon with three devices in use :cool:
Sep 3, 2009
1,532
6,284
NW Surrey
LHD Hymer exsis-i
Could you not mount a dummy TV camera on top of the aerial, then when you swivel it round looking for a wifi signal then the others on the campsite near you will think your the cops undercover and the bad guys will keep well away from your van.
Or the top of a periscope, then you could tell people that you have a MH-Uboat hybrid.
That's what I have done, with the added benefit that I can angle the antenna up or down, as well as rotate.
Malcolm
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Unit is fully painted now but it is raining so outside pics later.
I fitted a 36mm elbow secured with 1 m4 tapped screw.. The elbow coincides with the direction the panel is facing.It also prevents pushing it up too far.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Just before dark here at Beechwood Grange CC, finally stopped raining
The white sleeve is a neatly cut piece of 40mm OD waste pipe, also a perfect fit over 36mm mast. Makes a nice tight closure when mast is stowed.
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Andy, thanks for link. I have ordered parts and when they arrive will post photo's here of my iBoost setup. If mine looks as tidy as yours I will be a happy teddy.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I look forwards to your pictures. Imitation is the best form of flattery and don't be shy of any improvements (y)
Welsh girl
3,658
3,036
Globecar
so does the existing pole pull out easy please?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes Kev the wifi hub that allows all devices within range to share a successful connection requires a specific USB antenna. If however you use a different hub then the world is your Oyster. The point of the thread was to illustrate how to put it through the roof, the equipment used is not being considered.
