dash Cams.. a possible new order (2 Viewers)
Hammie
467
278
Neismann & Bischoff Arto
newbie/2015
My camera has just arrived, thank you for your efforts. Will try it out on Wednesday when I get back
Jaws
Jaws
23,836
72,510
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Certainly not until spring next year I am afraid.. sorry mate
Oct 8, 2009
484
352
Kent
Sunlight
32 years
I have a problem with my Jaws supplied dash-cam in that the gps will find my general location but zig-zags randomly around across fields and the sea, not following close to a track. I wondered if anyone else had a similar problem and had come up with a solution.
I am not expecting it to snap to a road like a navigation device, but I think it should follow a reasonable track.
Any help or suggestions would be valued.
Jim
paddyd887
38
31
great barford
pvc
Has anyone managed to use this device with Apple Macbook Pro as I am unable to read the information on the memory card as the format is non comparable - any advise would would be greatly appreciated. Thank you
D
Deleted member 29692
I couldn't make it work. I got fed up with trying and dumped the software onto the Windows machine I have hidden in the corner at work. It works perfectly on that.
If you want to keep fighting with it then a tip is that the format of the video files is OK it's the interface with the camera software that OS X can't do. The SD card from the dash cam is formatted to suit the camera not the media files. That's why you can't make your Mac read it.
I believe there is a way to do it. I just couldn't be bothered. (y)
Oct 8, 2009
484
352
Kent
Sunlight
32 years
I guess therefore that paddyd887 has not seen the video files and therefore does not know whether the gps works, NicNick, did your GPS work OK when you viewed the files on your windows machine?
Jim
DBK
18,033
48,138
Plympton, Devon
PVC, Murvi Morocco
Jim
Do you have the GPS aerial mounted so it can see the sky through the windscreen?
Apr 22, 2015
109
132
Wrexham
Auto Sleeper Burford
Since 2014
Yes mounted right at the front of the dash near enough right against the screen
Oct 8, 2009
484
352
Kent
Sunlight
32 years
I too have mine in a good position to get gps reception and am having no problems with my phone or pnd. I have tried the gps unit both ways around, ie the "sticky" side towards the window and towards the inside of the vehicle.
Do others mount it in any specific location?
Jim
