CV20 Teleco Arial removal. (1 Viewer)
Soots
132
556
Peterborough, UK
Elddis CV20 Impressa
Since 2020
Greetings everyone! I'm contemplating removing my TV Arial and put a blanking plate on, then if possible put a poynting antenna in place of it.
Where can I get a plate for it, please?
Apr 3, 2019
1,536
2,805
UK
Burstner Travel Van
Few years now
Cant you just fit the Poynting antenna over the hole?
Jun 5, 2020
41
43
Elddis Accordo 135
Since 2017
Just a thought - how about taking the flat aerial bit off the top of the pole? I don't know what sort of aerial you're thinking of fitting but if it's a bit like a chunky whip, one of the things I noticed about mine (on an Accordo) is, as well as the up/down, you can rotate the flat aerial so it's vertical - if you could do the same with a whip you could rotate the whip so it's flat with the roof, so it's less likely to be knocked off by a branch? But as I said it depends on your plan! Just re-read that and it's not the clearest thing I've ever written - hope you see what I mean!
Sep 17, 2017
5,525
10,339
Birmingham, UK
A-Class
I removed a similar TV aerial from mine and replaced it with a Poynting MIMO. It was an easy job. Took a couple of hours to strip the adhesive and sealant off and slap the new antenna on. The new antenna completely covered the old mess. I did 3d print a sleeve with an outside lip on the bottom to reduce the size of the hole. But other solutions are available.
Soots
Soots
132
556
Peterborough, UK
Since 2020
My son has a 3D printer ( maybe 3) that would give him a job, thanks @Guigsey.
