Clip release (1 Viewer)
Oct 5, 2021
411
363
Tropical Skelmorlie
Globecar 5.4 Shine
Since 2013
I'm trying to disconnect the pipe from the fuel pump outlet (Honda Vision 110).
I guess the green clip is holding it in place, but I don't know how to release the clip - nothing seems to move by pressing/squeezing?
Does anyone have any ideas?
GoldenVision
Oct 5, 2021
411
363
Tropical Skelmorlie
Globecar 5.4 Shine
Since 2013
I forgot to say the bottom is exactly the same arrangement as the top - so I tried squeezing the larger of the two green tabs together so that the smaller two are moved inward (which is what seem to holding the pipe in place) but they don't seem to move, and I don't want to use too much force
Dec 12, 2010
5,473
22,087
Cumbria
since 2011
I think you have to press pretty hard on the green part (both sides simultaneously) that's inside the square cut out then it's a wiggle to get it off ?
I must congratulate you on the clear photographs though, often on here, you can hardly make things out that people post !
GoldenVision
Oct 5, 2021
411
363
Tropical Skelmorlie
Globecar 5.4 Shine
Since 2013
Thanks - I'm sure you're right, I'm just a bit worried about snapping something. I'll try later with a bit more force...
GoldenVision
Oct 5, 2021
411
363
Tropical Skelmorlie
Globecar 5.4 Shine
Since 2013
Yes, that did it, although it was first necessary to slide the rubber seal (the L-shaped thing in the photo) up out of the way in order to enable the tabs to be pressed in.
Now I have to find out why no petrol is emerging from the pump :unsure:
