Citroen relay 2.2 hdi 2013 wont start (1 Viewer)
Feb 15, 2023
Citroen relay
Hi, I've got a 2023 citroen relay 2.2 hdi and its got some starting issue. It definitely has power, you go to start it and it's just one click, no crank. Yesterday it would start as normal after continuing to try it say 10-15 times. Today its much worse but still turns over as normal eventually. I've reset the bsi to no avail. Any advice would be greatly appreciated! I don't want to start changing parts unnecessarily.
Chris356
7
Hobby
Since 2010
You need someone to keep the key held in the start position while you give the starter motor a gentle tap with a hammer if it starts then it’s your starter motor that needs changing
Feb 22, 2011
9,853
20,319
Newcastle under Lyme
Hymer B544 A Class
Since 2015
w2f
If it's brand new the supplying dealer needs to sort it for you
