- Aug 7, 2013
- 284
- 172
- swift kontiki
- I'm a newbie bought our first motorhome 7months ago and love it
Anyone had trouble with the battery mine is less than a year old and won't work unless it's plugged in
The battery on mine doesn't last all that long in use, but that's something I've noticed with Garmin and TomTom models as well. It doesn't lose charge when switched off anywhere near as quickly as the TomTom.Anyone had trouble with the battery mine is less than a year old and won't work unless it's plugged in
Ours turns off as soon as you turn the ignition off then you have to reprogram itThe battery on mine doesn't last all that long in use, but that's something I've noticed with Garmin and TomTom models as well. It doesn't lose charge when switched off anywhere near as quickly as the TomTom.
Not the same trouble entirely, but the battery certainly doesn't last very long when unplugged.Anyone had trouble with the battery mine is less than a year old and won't work unless it's plugged in
Try having a look at settings, as I am sure you can customise the on/off sequence.Ours turns off as soon as you turn the ignition off then you have to reprogram it
If it won't turn on at all without external power then it does appear that the battery is kaput. Otherwise, it's probably settings as per Jock's post above.Ours turns off as soon as you turn the ignition off then you have to reprogram it
Can someone help please.
As my map update and adding other maps (not EU) going to be on the SD card, how can I change the Navi Path
from
ResidentFlash\Primo\PRIMO.EXE
To
SDMMC/ PRIMO.PRIMO,EXE
Can't find the way to add a new path to the paths list.
Sorry to be a pain people but I have downloaded the manual but cannot see were it tells you how to add poi. May just go back to the Tom Tom.. tHanks for all your help
My chinese satnav is loaded with poi's.......I bought a new Chinese Sat Nav , I nearly crashed when it told me to turn reft at the rights.
Buy a new 'un....lifetime map updates, 4 full map undates a year, regular user map updates....and lifetime traffic updates on many.My tomtom 1005 does John but I no longer use it. Tom tom mapping is expensive and not up to date enough.
It is called community content
I'm very happy with mine too, and have kept my faithful TT720 complete with my Truck maps, and customised POIs.........................just in case.They've been forced into that by customers voting with their feet.
I'm very happy with chinkynav.
Has your tablet got a Micro SD card inserted in it?Thanks John.
When selecting Navigation path setting window, the only option I get is the resident one. How to add the SDMMC Option?
Strange. The operating system should recognise the path even if the card is empty. It might be worth checking the card in a PC.Yes it have a SD card but without the maps yet.
Sorry, I'm mystified then.The card seems OK on the PC, it came with a file on it named: device.nng 1KB. I don't know what the file for and not sure if I can reformat the SD.
