Checking for Tunnels (1 Viewer)
Clickem
1,034
1,073
Northumberland
None
7 years
We are planning a trip to the Italian Lakes, for the first time, so we will be travelling up the sides of the likes of Lake Como, Iseo and Maggiore. Is there a way, such as in Google maps, of checking the routes for tunnels and their heights
TIA
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
We normally use CoPilot, and have the old Caravan Version which had the ability to input vehicle sizes, which is now not supported/updated. We use the updated version which has new maps but cannot input vehicle size. I still have both versions on the tablet and could try the "plan a trip" feature in the old version, and see if it sees any low tunnels
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
check carefully toll charges through the tunnels before planning the route.
Mar 29, 2011
961
639
Rugby UK
C Class RS
get a proper satnav with the entering vehicle size option on it, expensive but a little bit better than dealing with the damage
Apr 11, 2015
5,476
56,067
hull
Laika Ecovip 300
thinking of getting a cheap chinese one just for the heights and using tom tom rest of the time.
Feb 22, 2011
9,942
20,544
Newcastle under Lyme
Hymer B544 A Class
Since 2015
There are numerous tunnels but none should cause you a problem unless your in a double decker routemaster.
What is it your concerned about with tunnels ?
Edit, just read again, low tunnels ?
No there are none that should be a problem, trucks and buses use all main routes. If you go "off piste" they will be signposted.
Potholes are more of a concern in italy :(
Ridgeway
3,686
6,241
Lausanne
NiBi Arto 85E
Since 2012
What height are you ?
Unless over 3.5m i can't see any issues, coaches use these roads unless you want to go way off piste ? and in that case a MH is a bad idea in those areas, some i struggle on with my bike.
Feb 4, 2016
232
123
uk
10 years
Not used Co pilot since last May.....has it changed?......can you not use the dimensions anymore?
Any other issues?
TIA
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
The original Caravan version is no longer supported, so the choice was either stay with old version which has outdated maps, or change to the newer version which does not support sizes
