Charging System in 2007 Autotrail Tracker (2 Viewers)
Feb 10, 2024
52
38
Gloucestershire, UK
Autotrail Tracker
I have a 2007 Autotrail Tracker.
It has a solar panel and an MTTP Dual Controller which prioritises the leisure battery before charging the engine battery.
If I have the van connected to EHU I know it will charge the leisure battery but will it also top up the engine battery?
Oct 10, 2018
2,019
1,145
Bracklesham Bay, West Sussex
PVC
If your Autotrail Motorhome is fitted with a Sargent PSU 2007 or PSU EC 225/325/328/155 or 176 you need to select the battery to be charged (starter or Leisure) when on EHU .
Tombola
4,886
15,863
Merseyside
Rapido 8094DF
Since 2004
little black switch usually
Dec 24, 2014
9,296
47,945
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Easy way to check is to note the battery voltage off EHU with a multimeter and again when EHU connected. Obv it should be a higher reading with EHU connected.
Mar 14, 2020
681
544
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
If like my 2006 AT, you will definitely have to select the vehicle battery on the control panel as said above ⬆️. My solar also has a trickle charge to the vehicle battery but this plays no part when on hook up. I stick mine on vehicle charge overnight on ehu. Just remember to swap back over when you start using loads in the morning although emu should cover any drain. You could add one of the van bitz box of tricks?
DK1083
Feb 10, 2024
52
38
Gloucestershire, UK
Autotrail Tracker
Thanks. That’s helpful.
