CBE Control Panel & CBE Distribution Unit/Fuse Box (1 Viewer)
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Thats the odd bit ...my relay is switched from the control panel ..and as soon as it does the control panel lights up...
Andy.
Its all black magic Andy, I have only turned ours off once and that was when I changed the batteries when I connected it back up there was a resounding kerchunk from something but I don't know where so hopefully never need to know, since then I have not dared switch it off just on case.
Martin
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Yes that's were my information above came from, the only conclusion I can see on that thread is that the OP had his panel reprogrammed but it still didn't work properly.
Martin
Yes, Martin I edited my post after looking at the outcome. You would hope that the shutdown systems would protect the electrics from an expensive, if not fully functioning, repair.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
OK different box to ours Robert, we have both B1 and B2 on the same board you have the separate SB-150 taking B1 and B2 and I assume the switching for B2 battery charging when the engine is running is inside that as well, BUT what is the bit next to it with the blue light? do you think it is the split charge relay did it have a cover on with a name?
What model number is your Distribution Box?
Martin
I was told that the SB150 was the split charge relay when I bought it but that was by a hab service organisation not a main dealer and certainly not Travelworld. He was engaged by the Agent I bought the van off to cab and hab service it ready for my use. I have now taken the cover off to show the interior which does appear to have a relay in the middle.
The model number for the distribution box is CBE DS 450 with a number underneath but the 2nd digit has been smudged and is illegible! 2?9458.
The item with the blue light - I have no idea but its like an aluminium heat sink and the black central section is that black goo that they pour in to seal the electronics inside which goes almost hard. It has never ever had a cover and it looks like there never ever has been.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
I have now taken some more photos to try and show and evidence what is going on.
The 2 photos of the volt meter are to show firstly the power at the distribution panel which was 14.32 and the battery which was also 14.32.
The inside of my SB 150 is quite different to the earlier french one that someone put up earlier.
I have also shown the front and back view of my CBE 320 main controller, which is still not working!
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
I suspect the next step will be to buy one of each of the type of relays that I have and try a new one in each socket and see what happens. By all accounts once the voltage is above 13.5 or whatever the control panel is supposed to come on again automatically. I have the horrible feeling that I am going to need to buy a new distribution board on the basis that none of the other end user devices are working e.g. Satellite dish raising switch, Alde Hot Water/Heating controller, awning light and cooking hob and main CBE control panel.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
There is one relay that looks very common and that is the Zettler AZ9731-1C-1zDC2D2 NO/NC 40/30A 09X13 made in China. I have seen 6 of those so far!
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
View attachment 283222 View attachment 283223 View attachment 283224 View attachment 283225 View attachment 283226 View attachment 283227 I have now taken some more photos to try and show and evidence what is going on.
Hi Robert
I think the SB-150 is a different beast to the French thing, the SB-150 is the split charge where the French this is just an isolator I think. Still don't know what the thing with the blue light is but it seems to be directly inline with the 12v feed to the distribution box but you have power there so(y)
But I will be honest and say as far as fixing it I have not got a clue.
Martin
May 7, 2016
7,312
11,822
West Sussex
Malibu Van 640 LE K
Since 2003
Don’t forget the @Bobby22 post. From the link in that It appeared the fault was in the control panel not the distribution board. Possibly not an isolated incident either.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
The nearest dealer who deals with anything remotely like mine are Chelston who are Carthago dealers who seem to use CBE gear. It might be worth phone call as they are only about 40 miles away at Wellington. Other than that it will finding someone with experience of CBE kit.
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
There's a guy in Wales who repairs them. I'll find the link and post it later. Bottom line is when they fail they're knackered. Carthago wanted over a grand for mine, but when I traded the van in and disclosed the problem the carthago dealer charged me £350 for a replacement.......... Go figure.... Same panel as yours!
TheBig1
17,655
43,512
not being condescending, you have pressed and held the power button for up to 30 seconds?
Jun 10, 2010
8,580
20,357
Shrewsbury (sometimes)
N&B Clou Liner MAN
Hi Robert
Quite often stuff like this is a duff battery, I can see that you've tested the batteries as a pair, have you tried disconnecting one at a time?
Jon
Btw do you have PV's?
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
Rummaging around on the Internet I came across these people who seem to be very knowledgeable with a vast amount of helpful data on their website.
http://www.aandncaravanservices.co.uk
A lot of warnings about upping battery capacity when the rest of the system might not be up to it showing burnt out boards etc. They also have some very useful sounding advice on batteries. Looks like a good resource and they might be into repairing my bits. They are not keen on B to B's and prefer uprating cables instead. I'll be giving them a call.
Based in North Wales so maybe are the firm that @BreweryDave found.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
Hi Robert
Jon
Jon - I have 2 battery sets. The original was a pair of 110amp Hancooks which were 4 years old and which I have yet to test but I assumed that they might have an issue especially as they were the ones that ran down when the EHU tripped and the control panel shut off to save them. They have been recharged using my CTEK 25 amp charger but I have yet to test them.
The batteries now in use to try and get the system going again are a pair of Varta LFD180's which are fully charged and are showing 14.32 volts on the CTEK charger.
Please excuse my ignorance but what are PV's?
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
The instructions say to hold in for 2 seconds so I have held it in for much longer than that but probably not as long as 30 seconds so I will try that tomorrow. Thank you.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
Seem to have the 320pc control panel for £186 here
Whilst that is the right standard master control panel the N + B version is customised for N + B and is not the same as the one that I have. I daresay that I will either have to get my unit repaired or by from a N + B dealer or direct from the factory to get the right one.
Jun 10, 2010
8,580
20,357
N&B Clou Liner MAN
Solar panels
Lenny HB
53,793
151,461
On the coast in West Sussex
Hymer B678 DL
They closed down their workshops some time ago due to health problems but Alan still does some repairs at home depending on his state of health. Worth giving him a ring a very helpful guy.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
Solar panels
Hi again Jon - now I recognise the term Solar Panels!
Yes I had Vanbitz put 2 on the roof but they are wired though Victron controllers straight to the batteries and not via the N + B electrical systems.
Jun 10, 2010
8,580
20,357
N&B Clou Liner MAN
Photo-votaics, they can have a strange effec
Is it worth covering them and disconnecting just to be sure?
I'm sure they would have been fitted correctly but components can fail.
funflair
19,467
30,805
Guisborough
MORELO palace
since 2012
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
Hi Jon
In changing the batteries over I had to disconnect the solar and that is easy the way VanBitz do it as they provide inline fuses that you can just remove to stop the power flowing.
Abacist
Abacist
3,811
11,292
Devon
N & B Arto 88F Tag
since 2013
So back to the thingy with the blue light, I think it is a Victron Battery protect device (old model) most likely inherited when VB fitted solar etc, I can not find anything that tells me what status the blue light is reporting in its on state is it usually on Robert @Abacist https://victrondistributors.co.za/wp-content/uploads/2018/01/Datasheet-Battery-Protect-EN.pdf
If it was mine I might be tempted to bridge it out or bypass it just to make sure it's not playing silly B's.
Martin
Well discovered! You did very well to find that - like a needle in a haystack!
That was there when I bought it so I imagine that its original N + B fitment. It is certainly nothing that VB added. The previous owners were the sort never to touch anything! The blue light is always on when there is a charged battery connected and off when the battery is disconnected.
However your idea is a good one as there is a little black wire that goes off into the distribution box so is connected to part of the brain of the thing and may well be affecting the coming back to life!
R
Robert Clark
Martin
We’ve got a similar one in our van, with a flashing blue light.
Disconnects the load from the leisure batteries if the voltage gets too low.
Should automatically reconnect when the voltage increases.
We’ve akso got a separate switch which throws a relay which also disconnects all the loads from the battery.
