Camping Gaz Burner fed from the van? (1 Viewer)
Dec 31, 2017
162
193
Cheshire
Carthago Chic C-Line
A Camping Gaz Cadena burner question to the collective
I have a Camping Gaz Cadena single burner and instead of using the blue Camping Gaz bottle I would like to make use the onboard propane system in the van
Has anyone seen a small stand and converter to do this?
I may just end up buying a single burner from another manufacturer and supply from the van but before I do just wanted to check that there isn’t a stand, bracket/adaptor out there
Kannon Fodda
2,607
8,067
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
I doubt it would be doable at economic cost. The Camping Gaz bottle is probably a much higher pressure than any low pressure feed from the LPG system via a BBQ type extension hose on your motorhome. Thus the burner on the Camping Gaz unit wouldn't get enough gas to operate fiercely enough.
I know that Cadac do high and low pressure versions of many of their Safari Chef type BBQ's because of the differing use of the disposable bottles and the larger cylinders.
