Cadac safari chief 2 (1 Viewer)
Dazz
300
316
South Wales Valleys
Ford Chaussonflash02
Newbie
Hi all I’m after advice I just purchased a cadac safari chief 2 .It doesn’t have gas connection ect so I’m not sure what’s best to connect I know I can connect low pressure disposable cans but not sure how long they last .My Motorhome only has room for one bottle so do people disconnect the van gas and use that or is there an adapter to that runs off one bottle to connect to cadac any advice appreciated thanks
Oct 17, 2013
703
19,119
Plymouth
Adria Compact
Since 2013
I think most use an external gas point on their van. If you don't have one they can be retro fitted
MisterB
5,879
13,172
Essex
Adria 670 SLT
is it a HP (high pressure) or LP (low pressure)
HP works of small gas cannisters
LP works with a hose and connects to a cylinder via a regulator or has been suggested (and is really useful) an external gas point, which means you dont need to worry about carrying cannisters or an additional cylinder.
its not a big job or difficult so long as you are competent to do the job ...
Oct 20, 2016
1,000
12,027
Northampton
Autotrail Imala 625
Since 2016 and caravanning before that
I use a camping gaz 907 cylinder. I do like the idea of an external point but I also find I do cook some distance away for safety
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
There are two models of the safari chef.....the HP and the LP.
The HP model which only connects to the disposable cans and the LP model which is for use with propane bottles.
You can buy a pig tail adapter for the for the LP one to make it work with disposable canisters, but you can not do it the other way round with the HP one.
Cadac Safari Chef 2 Lite Low Pressure Gas BBQ Amazon product ASIN B079T19KW1
Cadac EN417 Hose and Regulator Amazon product ASIN B00481D8JM
Cadac 6540H1-10-EU Safari Chef Amazon product ASIN B01BLFCP6E
Dazz
Dazz
300
316
South Wales Valleys
Newbie
Thanks all it’s a cadac safari chief 2 LP
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
Have you got a hose connector with it?
I carry the HP pigtail adapter and a 6m LP hose set up (which is what I normally would use) I didn’t fit an external bbq point but fitted a quick release fitting in the gas locker.
I only have one small 6Kg bottle in the van gas locker, but what I do sometimes is take a spare 3.9kg bottle with me on longer trips......I then use this for the cadac, but also It gives the option to connect to the van should I run out on the main 6kg bottle. (It’s never happened yet)
Jan 11, 2010
2,749
9,579
Chester
Auto-trail
Well that`s our 13th year & still loving it.
Hi Daz, simple job to connect to a LP bottle, ebay will provide the fittings and Gas Pipe.
I have just bought this for mine.
Minxy
32,662
66,577
E Yorks
Carthago Compactline
Thank goodness you've got the LP one ... the ones that use the disposable canisters are IMV not very good.
Jan 6, 2017
614
2,619
East Devon
Murvi Morocco XL
since 2014
Any reason why?
We (inadvertently) bought the 'canister' version and find it works very well, and particularly abroad the canisters seem to be pretty cheap. As we don't have external point it means we don't need to carry a large gas bottle and the small replacement cartridges can be stored in small holes. The only problem we have found with ours is the piezo ignition device is rubbish so we light it manually.
Minxy
32,662
66,577
E Yorks
Any reason why?
When we had one it was pants, took ages to cook anything, maybe they've improved the efficiency as there used to be a big difference between the HP and LP versions cooking ability.
Kannon Fodda
2,581
7,991
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
I have the LP version with cannisters connected via the hose adapter. Creates more portability than being tied to a hose point, if I had one, on the van. Temperature for cooking is fine, usually have to keep it quite low else things will get cremated quite quickly, and it's only once it's close to running out that it gets a bit more iffy but a shake of the cannister usually solves that. The little cannisters seem to last quite well, certainly for a few BBQ uses where I can get a good 4 or 5 cremations before they run low.
lorger
9,665
90,531
Dumfries
Knaus Sun 650MEG
If you want a BBQ point without drilling hiles in the van have a look at this.
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
That’s what I fitted inside the gas locker......
Dazz
Dazz
300
316
South Wales Valleys
Newbie
I just looked in my gas locker and this is fitted does this look like system above
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
No... that’s just your normal regulator.....
the system shown ‘T’s in after the regulator before it goes through your wall.
Jun 22, 2011
507
1,305
Onchan, Isle of Man
Carthago
Since Nov 2010 after 25 yrs under canvas.
We have tried 3 cadacs , on the basis that because others think they are good we must be doing something wrong. Not once have I managed to produce a good steak on a cadac. They just don't do it. I loved my lotus grill, now dead, but replaced by an equally good cheap chinese copy from Lidl.
I have an ambition to find someone who has a cardac who can convince me they are any good.
swiftsteve
320
803
kent
Adria Coral S 680 ST
Since 2008, with a gap between 2013 and 2018.
We have an external gas connection on our van, but I bought one of these and an extra length of pipe; so we can use it in the garden. https://www.google.com/aclk?sa=L&ai=DChcSEwjHyYa9j4fqAhV2gFAGHTEtAckYABAGGgJkZw&sig=AOD64_1rKN03EFCm74RU35Ug42Dasn5DBA&ctype=5&q=&ved=0ahUKEwiykIK9j4fqAhUqQEEAHdEBBhEQwzwIDg&adurl=
swiftsteve
320
803
kent
[/QUOTE]
We're on our 2nd, the 1st spontaneously combusted and melted for no apparent reason. It was replaced free of charge. I quite like it, but I get your point about cooking steaks, although the same could be said about most barbecues.
I only bought one because the van had an external gas point. For burgers, sausages, chicken drumsticks etc. they are more than adequate. For a medium rare rump steak, a pan on the cooker is much better and only about 2 metres further away.
Aug 31, 2014
489
689
Surrey
Coach built
4th year
3 mins each side for perfect medium rare “jo Blake”
Jun 17, 2019
478
620
East Yorkshire
Just looking
One a newbie
Have large cadac which we love except for cleaning😬
Bought the small chef 2 which I’m very disappointed ,bbq plate ruined after 3 bbq’s due to cleaning certainly Not none stick.
Mar 15, 2021
145
146
VW T5
Do you find it works Ok with a 6m hose, cadac recommend 3m max
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
Yeah, I’ve never had any issues or noticed any difference using a 6m hose, a 1m hose or the HP pigtail canister adapter. 👍🏼
