Cadac safari chef 2 lp (1 Viewer)
Dazz
300
316
South Wales Valleys
Ford Chaussonflash02
Newbie
I’m having bit of trouble cooking a pizza on my cadac it’s burning the underside of the pizza I pre heat the pizza stone then I turn the heat down and then put plenty of flour on the pizza stone and then place pizza on the stone and place lip on to cook but it’s still burning underside of pizza any tips
MisterB
5,882
13,188
Essex
Adria 670 SLT
Try leaving the lid off. They can cook very quickly so it's a bit of trial and error but too much heat can be as bad as not enough
DBK
18,033
48,138
Plympton, Devon
PVC, Murvi Morocco
It should cook in a few minutes if the stone is hot enough. But if it's actually burning it might be too hot. If you just sprinkle flour on the stone without the pizza does the flour burn? If it does the stone must be far too hot. Which surprises me but I guess it could happen.
Feb 16, 2013
19,736
52,043
uttoxeter
ambulance conversion
50 years
Never seen such an over priced, over praised piece of motorhomeing kit in my life.
Disposable BBQ things knock them to cocked hats.
Boris7
Banned
Jan 27, 2020
1,043
12,413
Auto Sleeper Burford
1 year
Your probably seeing a burnt layer under the pizza that you can peel away, if that’s the case it the flour burning not the pizza itself.
This is a sign of too much flour being used/flour being put onto the stone before the pizza is put on.
When you roll out the dough, the flour on the board should be all you need, if you do add any to the finished Pizza, put it on the peel, not the stone and only use very little.
If you prefer American style then don’t use any flour on the peel, use oil.
If you want a really good pizza then the answer is here https://uk.ooni.com/products/ooni-koda
