Hi folks
This is my first post so please forgive me if I don't get the etiquette of the forum quite right.
We can't use the water system in our motorhome because of a leaking tap and we supposed to be going away this weekend for Valentines!
We have a Burstner IXEO 586 2015. It has the swing out basin in the bathroom. The pivot of the basin is sandwiched between 2 shelves that are built-in. The basin tap sits on the top shelf and it's water tails go down through the pivot of the basin.
The tap has got a leak - I've changed the cartridge and Reich (tap manufacturer) have looked at the tap and said that it is leaking from where the tails go into the base of the tap probably. So I have to remove the tap to try to fix it and maybe even replace the tap.
My problem is I can't see how to remove the tap. I can't get access to the underneath nut holding the tap on the shelf because I can;t get my hand or any tools up through the basin pivot. I could maybe dismantle the shelves and basin to remove these but I can't figure out how Burstner have fixed everything together and I don't want to damage anything.
I have asked Burstner in Germany for guidance on how to replace the tap and they wont tell me. A UK dealer asked on my behalf and Burstner came back and said loosen the nut up through the pivot which as stated above is impossible to do I think.
Have any other Burstner IXEO 586 owners replaced the bathroom tap? - and if so can you please tell me how you did it?
Many thanks
Tim
Many thanks
Tim
