Bessacarr 597 (1 Viewer)
Apr 12, 2021
203
84
Next to The Rusty Angel
Race Van
Hi All,
I have recently purchased a 597. Can anyone tell me what the inspection hatch in the floor near to the sink area does?There is a screw top possibly for waste water but I can see straight down to the road. Is there something missing?
May 14, 2021
1,742
2,791
East Yorkshire, UK
ADRIA Twin 640SLB
Since 2012
I had an E480G and whilst a photo would be best from your brief description it is the access to the fresh water underslung tank.
That is the screw top which you have to undo to reach through to manually pull out the rubber bung to empty the tank.
The bung should be on a stainless steel chain so you don’t loose it but best to pull it out with the bung not the chain.
Oct 31, 2017
534
1,194
Kent
Carthago T149
Since 2016
Hi All,
Its just to access the top of the ( fresh I think ) water tank. You can see to the road below in ours. I did tape some quilted insulation over our hole ( pardon the expression ) as it gets blooming cold.
May 14, 2021
1,742
2,791
East Yorkshire, UK
ADRIA Twin 640SLB
Since 2012
Just to clarify.
Yes you can see the road possibly over the edge of the plastic tank but I took the hole the OP was referring to is the one directly below the screwed cap where the rubber tank bung fits to stop the water running out.
Jul 31, 2019
875
8,256
Devon
Swift Bessecar 584
Since April 2019
Like RogerS, and having a Bessecar 584, should be access to cold water tank.
