- Sep 7, 2021
- 233
- 520
- Benivan 120
- Since 2021
Part of the fun (for me anyway) of a motorhome comes from having something to tinker with and improve. Something to do with your van when you can't actually get away in it So... I thought I would post a thread on the tweaks and improvements that I have made to our Benivan 120. Maybe the information will be useful to other Benivan owners (or to Auto Trail PVC owners for that matter, as in spite of the Benimar name, the Benivan is made by Auto Trail and has a lot in common with their vans).
I'll start with a couple of simple bathroom tweaks...
First, a 3D printed box to hold the hand soap bottle on the sink top. A few strips of double sided tape on the underside to hold the box in place and the soap bottle is not going to slide around anwhere when you are on the road. Another hint - drill a small hole in the neck of the soap bottle just below the lid (2mm or so). This lets air into and out of the bottle. Without this we found the soap was pumping itself out due to the temperature changes over the winter.
As you can see from the image above, the Benivan has a tip up sink unit in the bathroom - the idea is that the water drains out when you tip it up (no plug hole in the sink). This is fine in theory, but if you are a bit swift tipping the sink up then the water doesn't go into the drain down the back, but instead dribbles out down the front of the lower part of the unit and onto the shelves below
Fortunately there is a thing called 'Silicone seal strip' - clear/translucent silicone tape that has self adhesive tape on about half its width. It's designed for sticking to places like the bottom of doors, so that the non-adhesive part reaches to the floor and cuts out a draught, but I've stuck it to the lower part of the sink unit to help catch any dribbles and guide them in the right direction.
It's fairly subtle against the white of the bathroom unit and seems to be doing the job OK.
Next time... strengthening the wardrobe wall to mount a TV.
cheers,
Robin
cheers,
Robin
