- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
Also the new one is equivalent to a 75cm dishTo get you to buy the "new improved version" for an extra £400
As far as I'm aware they are both single LNB.Are they all twin LNB?
Looks like a bargain?
Broken Link Removed
I would definately have the twin LNB if I was buyingAs far as I'm aware they are both single LNB.
The importers Avtex say equivalent to a 60cm dish were as the basic Snipe is equivalent to a 65cm dish.Also the new one is equivalent to a 75cm dish
That's the Pro Max at £1400Also the new one is equivalent to a 75cm dish
Yes I said "The new one"That's the Pro Max at £1400
Ahh, that new one, I thought you meant the other new oneYes I said "The new one"
I stand corrected Avtex don't even list the Pro on their website and they are the importers.Says equal to 75 here
Broken Link Removed
But there isn't a Snipe with a twin LNB new or old.No brainer
Old model twin LNB including brackets UK seller £669 delivered
Broken Link RemovedBut there isn't a Snipe with a twin LNB new or old.
Look at the 2nd photo only two connectors, they are both standard F connectors one for the single LNB and one for the controller.Broken Link Removed
Simple installation
Simply connect the antenna, within seconds it is ready to receive a signal! The antenna is already prepared for a permanentinstallation. At the base of the antenna, there are six characteristics that are provided for screw mounting. An adapter plate is as important for delivery.
Specifications:
LNB Type: Twin Universal
LNB input frequency: 10.7 ~ 12.75 GHz
LNB Output frequency: 950 MHz ~ 2.15
Signal Gain: 33.8 dBi - 12.7 GHz
Satellite search time: 60 sec
Suchgeschwindikeit: 5-10 ° per sec
Polarization: linear (horizontal / vertical)
Elevation angle: 15 ° ~ 75 °
Tilt: -60 ° ~ +60 °
Azimut: Unlimited (360 °)
Operating temperature: -30 ° C ~ +60 ° C
Color: White
Antenna dimensions:
Length: 510 mm Width: 357 mm Height: 188 mm
Weight: 7 kg (antenna)
What's in the kit:
SNIPE satellite antenna
Controller unit
Controller cable (12m)
Satellite cable (12m)
wall Mount & base plate
Durable hard case
I've sent them a message asking the question.I imagine it is merely a generic image, the same seller also sells single LNB cheaper.
