AVTEX 19" /. AMAZON FIRESTICK (2 Viewers)
Jan 30, 2014
631
475
Midlands
IH 630 FL
Hi, looking to use the firestick in France, but amazon say me must only used it with a tv which has a 900aA USB NOT a 500aA, does anyone one know how I find this out and what difference it will make. Never used a fire stick, and looking at all problems people seem to have, I wouldn't know what to use instead. Are they easy to use?
Nov 5, 2019
902
1,770
Arkley, Barnet, UK
Corinium Duo
Relative newbie
I've covered all bases with a 12v ciggy lighter to twin ciggy lighter and high amp usb extension of a certain website.
Nov 4, 2011
5,996
40,077
Uk
My Firestick works fine of tv usb (finlux tv) but I heard they’re best off a better usb for doing updates.
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
The first time setup is when a Fire TV Stick seems to be the most power hungry.
Just in normal use lower ampage power source is OK
May 5, 2022
1,842
8,372
Kidsgrove, North Staffordshire.
Hymer B778 PL
Since 1992
Can anyone tell me how I find this out on my tv though 900aA USB or a 500aA USB
Does the handbook for the TV tell you?
We have a 3 year old Fire Stick which came with a 240 volt plug to power it. Amazon will sell you a new "upgraded" stick which RNs off the TVs usb port. Save money ney and just detach the 240 volt plug and stick it in the back of the TV. Mine works a treat.
What you can watch depends on what broadband you are connected to. There are plenty of threads on that.
kevenh
3,319
11,801
Thatcham
Compass C-Class
Fire TV Sticks tend to be OK after the setup stage.
Is the OP having an issue or worrying about one undiscovered?
tinkerbell
Jan 30, 2014
631
475
Midlands
IH 630 FL
Always had dish on roof, no more so no idea how it all works now with fire stick, etc so not sure what to use abroad
MisterB
6,049
13,560
Adria 670 SLT
as with all things, set it up in your house and try it in your motorhome before you leave on your travels. Youre probably asking questions to yourself in your head that will become glaringly obvious once youve tried it.
it really is simple, so dont put additional pressure on yourself by worrying about it.
Sep 17, 2017
5,599
10,468
Birmingham, UK
A-Class
You won't break anything to try it. The worst that can happen is the FireStick might flake out and crash when it's doing a lot of work. They are robust, so might just need a restart. As others mentioned, this is probably just when it's doing things like installing updates.
tinkerbell
Jan 30, 2014
631
475
Midlands
IH 630 FL
Yes, I think worrying comes with getting older, now, what fire stick to I get, so many Amazon ones out there
Oct 23, 2022
76
147
Southampton, UK
Benimar
Since 2020
We have a 2020 Avtex 19" TV and Firestick. The Firestick works fine off the TV's USB port - and that includes having done software updates and app downloads when out and about using a tethered connection to my phone.
kevenh
3,319
11,801
Thatcham
Compass C-Class
All the current generation, new, Fire TV Stick are noticeably better than older HD versions.
But wait until the range are discounted.
Then, either of the 4K versions are a good step. The dearer 4K Max one has WIFI 6 ready to go - if that's something you can use🤷‍♂️ :)
Nov 4, 2011
5,996
40,077
Uk
For abroad, I’m using a RWG phone sim in a Huawei router and watching tv using a 4K Firestick and it’s mean working well .
I do have a satellite dome but at the moment that has an issue, so not working, I’m glad I have the Firestick.
Also with the Firestick you don’t need any subscriptions because there’s enough free stuff available.
Oct 23, 2022
76
147
Southampton, UK
Benimar
Since 2020
I wouldn't bother with 4K version. You'll never notice the difference on a 19" screen and the data usage rate will be much higher. For once, the cheaper option is best!!
Sep 25, 2012
522
1,228
West Cornwall
13 Years, 20 years with a caravan
I have a firestick 4k on my Cello TV and bought this to increase the power for the USB. Works really well as I prefer to use 12V socket rather than plug into mains with an adapter for the TV. This way it eliminates the need to use the Amazon USB plug into the mains for certain updates.
Mission USB power cable.
Amazon product ASIN B078KSHVCSPhil.
kevenh
3,319
11,801
Thatcham
Compass C-Class
When they’re on sale, the 4K Fire TV Stick is not much more than the best HD only option.
Looking today though, there’s been a price hike on them.
I’d wait for a sale.
Or if you don’t have or plan to have Amazon Prime, look at the similar Roku range:
FWIW, there’s likely to be a Prime Video app for Roku. TBC
Sep 17, 2017
5,599
10,468
Birmingham, UK
A-Class
You don’t need 4K stick but they have better processors I believe
And possibly more power efficient. Also likely to have a longer support life.
So yes, there are advantages to getting the better units beyond the higher resolution that you won't be using.
Stonemags76
1,286
4,008
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
Yes, the 4K stick is faster, & seems to pick up signals better I think? Any will fit your tv - had two Avtex tvs - an old one (2011] & a brand new one - and have just plugged a Firestick in & it works - always plugged into usb. As long as you have data (from phone, wifi or MiFi) it will detect it & play (after you’ve put the wifi password in)!
17,664
43,546
The 4k max is much faster processor and better wifi. You definitely don't want to run it at 4k in the van though. Just go into settings and choose a lower quality stream. What this means is that you will be downloading much less data. However on a small screen you will not see a difference.
kevenh
3,319
11,801
Thatcham
Compass C-Class
We’re on to the 3rd Generation of HD Fire TV Stick (available 2020) and it also has the power benefits of the quad core CPU fitted in the 4K Max FS Gen 1 (2021) and 4K FS Gen 1 (2018)
The 4K Max gets a 0.1GHz CPU advantage to them.
It could be the extra DDR RAM the 4K Max has helping with any marginal performance gains. 0.5GB more than the 4K or 1GB more than the HD only gen 3 version.
The Fire TV Sticks that are noticeably sluggish in menus are the old generation HD sticks. So, if buying 2nd hand, look out for those old sticks.
Lots of spec details and identification pics here:
Jan 16, 2014
1,354
2,502
Surrey
Rapido 854f
Yup bang on. We do the same. As said above it appears they need a little more juice on start up and this acts as a buffer
Feb 22, 2016
3,641
11,004
York
Bailey 620 Approach
Anyone got any iteration of Firestick to operate the volume on the Avtex tv by using the Firestick remote?
