Autotrail Tracker EKS SE (( Snags)) (1 Viewer)
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Hi Folks..Finally got the above van and there are a few little probs and I would be most grateful if someone could shine a light into my dark world...
1. Peizo ignition for the cooker and hob rings won't work.
2. Fridge won't light on gas.
Any pointers will be very much appreciated.. The van has only done 950 miles so It may be lack of use, even though its 2 years old...
I look forward to your replies... Mitch and Jenny..
haganap
12,759
26,448
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Ok, Cant help with the first one but will give some help with the second.
This is a common thing with a lot of Vans, shown to me by Ash when having had problems with mine.
Behind the bottom firdge vent, if you take it off from the outside ie the striker from the gas. For some reason and unbeknown why, it some times move so teh ignitior is too far from the pilot striking light. a little screwdriver very gently to re-introduce them to each other normally solves the issue with out a problem. It has to be done gently and without moving that bottom fridge vent, what im saying will make no sense whatsoever.
To remove teh outside fridge vent there should be two catches that simply slide inwards and then allow for the release of the vent cover, then have a look at it and all will make complete sense. :thumb:
As for the first problem, mine never ever has worked on any van, well not consistantly , the best present I ever got was from Mrs Tick59 a lighter thingy, you know the sort i mean.:thumb:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I know mine is a totally different van, but my igniter works from a 12v supply and unless 'Aux1' on the control panel is on the igniters do not work.
scotjimland
2,334
10,102
A Woosh bang
Most fridges and some cookers require a 12vdc supply to operate the igniters .. with both not working I suspect it's either switched off at the main panel, or a common 12v fuse blown.
MitchandJenny
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Since 2010
Thanks to you 3 chaps, I will give it the eyeballs in the morning.. Thanks again, I will let you know if / when I succeed.. Mitch..
haganap
12,759
26,448
planet earth
Good points .. I am assuming there is no 12v problems and with your cooker, have.a Look and see if you can see e igniter actually working but just not lighting the cas
Jul 1, 2010
3,199
33,521
SW Northumberland
Hymer B 588 DL
Since September 2010
Hi Guys
If the 12v control panel above the door is not switched on peizo ignition will not work
Enjoy the Tracker, and if we can be of assistance just ask
Stewart
K9Brian
605
575
South Manchester
Since April 2010
At 2 years old your van should still be under warranty. I think I'd be getting the dealer to explore rather than having a fiddle myself
MitchandJenny
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Since 2010
Thanks again chaps.. Yes the power is on above the door, but the peizo switch itself has absolutely no effect,, not even clicking, so tomorrow I will check the switch with my multimeter and take it from there..... The isolating gas tap for the fridge is on, so I will try haganaps suggestion about the fridge cover and move the auto peizo point closer to the pilot light and see what happens....thanks again fellas.. Mitch..
