Autoquest Rear View Camera (1 Viewer)
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
Anyone got any tips to solve a niggle
The Elddis Autoquest “specials”, ( Majestic,Prestige,Evolution...whatever) come with a factory-fit rear-view single-lens camera
Within 30 seconds of any rain- spray occuring you cant see a thing
Is there a shroud or any other solution/aid to this as an off the shelf bolt-on?
Suggestions?
Aug 6, 2013
11,959
16,576
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Where is the camera mounted? Mine is high up & has no rain shield (it's a CCTV camera) and although the view is affected by rain it remains perfectly useable.
Cheshirecat57
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
It us high up but almost flush with panel, gets covered in rain after 2 minutes of spray
Do you think rain x would work?
Aug 6, 2013
11,959
16,576
Kendal, Cumbria
since 1999
Definitely worth a try. Otherwise a small fabricated shield above it. You could experiment with small off-cuts of plastic trunking stuck on with 3M tape. A final shape could be done very neatly with that stuff. It isn't possible to prevent spray getting to it but a shield might modify the airflow over it.
Cheshirecat57
Cheshirecat57
3,482
5,590
Mid Cheshire
None
10 years on and off
Jul 29, 2020
110
260
New to motorhomes, had a camper van before this.
The one on our 115 is ok in good light. Next to useless in strong sunlight, twilight, darkness or anything more than a light shower.
Aug 12, 2020
1,401
2,354
Edinburgh
Accordo 120
Sept 2019
Suggestions?
Same issue with our Accordo, bad enough in the summer but in the winter with the low sunlight and salt water spray of the roads ...much worse. I use rainX on it but to little avail. I now have a mop on an extending pole plus a spray of washer fluid. Anytime I stop the camera gets the treatment. In addition to a hood to disrupt the airflow, I think it needs a jet wash or wiper
Aug 18, 2014
23,877
134,632
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Sounds like you need to break up the air flow allowing the spray & muck to be drawn on to the rear of the vehicle. Like a tiny aerofoil above it to make the air continue rearwards rather than curling back in?
Scorpion
Elddis Majestic 105
An Aerosol lid from a deicer spray or similar will slide over the camera unit. Just cut the top off the lid and slide over. Will need a couple of cut outs around the screws mounting the camera. May take a couple of attempts to get perfect but lids are plentiful. Not 100% cure but certainly works against bright sunlight and costs nothing.
