- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
Fuse and holder from china £6.99
Eddie I appreciate what your'e saying about metres and metres of extra cable and RCD protection. However mine is not strewn around outside or across floors or indeed anywhere where it could be subject to mechanical damage and earth leakage. It is all either fixed or inaccessible and overload protection is afforded by the 10 amp fuse in the 13amp plug going to my relay.
The actual length of cable is barely longer than that that is found on most portable appliances.
It is possible to do that in many households that still have no RCD protection.
There has to be consideration of likely hood and I certainly wouldn't use and electric kettle on inverter with a sink full of water. Most motorhome sinks you struggle to get a cup in never mind a kettle
what's an INERTER please
Why make it so complicated? I just fitted a 16amp socket to the inverters outlet, and plug my EHU lead straight into it, simple. cheap and foolproof.
Ian
I turn the charger off haggers. If your on EHU you don't need the inverter, when I unplug the EHU I plug into the inverter, walk in the van and turn the charger off and turn the inverter on with its remote switch, now all my circuits 110 and 230v are live, fused and protected by the existing RCCD.
Ian
Again IAN it is live and neutral not pos and neg and you require an earth
