Are all wheels equal? (1 Viewer)
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
Need to buy a spare wheel for Ducato motorhome (2021).
Is a wheel of the right size (and bolt pattern/etc) like any other wheel? What I mean is, there aren't "Motorhome" wheels (for, example, the extra weight), are there?
I need a 225x75xr16 5x130 wheel. I can get this identical looking one £228 (to my eyes at least) :
or this one for £160 with tyre (which I'd dump for my spare which is the same as the rest of my tyres) :
And there are steel wheels even cheaper (though I read somewhere on here that the bolts might not fit from the alloys, though I guess I could carry those spare too?)
I wish high street shops still sold wheels, so I could take it in and get their advice directly. Nowhere around here does, and if I buy the wrong wheel I canonly imagine the faff trying to send it back.
daventess
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
Your probably aware but there are two stud spacing sizes depending if it's a light or heavy chasie
Is that the 5x118 or 5x130? If so, I believe mine to be 5x130 as I measured 76mm between the centre of two side by side bolts.
MH is an uprated 3.5t (to 4.4t) so I would assume a heavy chassis, but i don't know how to confirm that.
daventess
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
You can of course use a steel rim as its is a spare and your tyre.
I thought there was some issue with that? Though logically, I can't think what it is.
So I would be fine using a steel wheel as a spare when the rest are alloys?
The Coops
1,850
34,973
The Fylde
Adria Compact DL
Yes, thank you
Yes no problem at all its the tyre that will need balancing on the rim and the studs are fine see previous posts by Lenny HB and other on stud issues
3,793
8,167
Milton Keynes, UK
Burstner Lyseo 727G
Have you seen the tiny thin space saver 'bicycle' wheels a lot of cars use? As long as it fits with the studs/bolts/dockets then it's fine. I'd suggest that for temporary (get me to a garage) use even a slightly different size would do.
2,138
6,450
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
Agree with you. Wasn’t the stud/bolt issue previously brought up in relation to someone using aftermarket, (non-Fiat), alloys? In any event in some countries it’s going to be a mandatory recovery before replacement, so having the tyre available is likely to be the more important factor.
4,194
9,406
South Lincolnshire
Rapido 7065+
Broken most bits now
You need to know the axle weight allowed and then make sure the wheel can support over half the weight. If the van is 4400kg then the rear axle will probably be about 2500kg so you need a wheel that can take 1250kg
Upvote 1
2,574
11,337
For Sale
Re Bolts
I replaced four Alloy wheels that were leaking and not suitable for high pressure valves with with new steel rims
... same bolts used
you can fit a slightly shorter stud with steels but not essential; .. they were changed by a tyre fitter who gave that information
4,194
9,406
South Lincolnshire
Rapido 7065+
The top wheels are only 1200kg which is probably limiting the rear axle to 2400kg and 4400kg total.
daventess
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
How do I find the load capacity of the wheel? It doesn't seem to be a quoted figure (or at least I don't recognise it as such) ?
JRT
Feb 28, 2023
388
1,195
The former North Riding of Yorkshire.
Nearly did....but...
40 years caravanning.
The spare on our Kuga is steel. (Space saving)
The main wheels are alloy.
Ok for short distance and reduced speed, enough to get you to a puncture repair place or home if close by. Not sure why it would be different for a MH.
1,836
15,894
South East but not London
Rimor Europeo 87
Five years plus three tugging
Agree. I uprated to 225 70 R15s from 215. However the spare is still a 215.
1,836
15,894
Rimor Europeo 87
RatingWeight
108​
1000​
109​
1030​
110​
1060​
111​
1090​
112​
1120​
113​
1150​
114​
1180​
115​
1215​
116​
1250​
117​
1285​
118​
1320​
119​
1360​
120​
1400​
121​
1450​
122​
1500​
123​
1550​
124​
1600​
125​
1650​
126​
1700​
daventess
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
RatingWeight
108​
1000​
109​
1030​
110​
1060​
111​
1090​
112​
1120​
113​
1150​
114​
1180​
115​
1215​
116​
1250​
117​
1285​
118​
1320​
119​
1360​
120​
1400​
121​
1450​
122​
1500​
123​
1550​
124​
1600​
125​
1650​
126​
1700​
Sorry I still don't get that - I've not seen a wheel with that number on it (or again, maybe I just don't recognise it as such). I've seen tyres, but not wheels.
1,836
15,894
Rimor Europeo 87
Wheels or rims, are (mostly) wheels. The load index is for the tyres you put on the wheels.
You have to investigate the Load Index through the tyre manufacturer website.
4,194
9,406
South Lincolnshire
Rapido 7065+
It's usually cast into the wheel inner face. It's sometimes given in the advert but often omitted. The heavy chassis is often borderline on wheel strength so you really need to ask the sellers.
The tyre load rating is a different thing all together and is only relevant to the tyre itself.
54,250
153,410
RatingWeight
108​
1000​
109​
1030​
110​
1060​
111​
1090​
112​
1120​
113​
1150​
114​
1180​
115​
1215​
116​
1250​
117​
1285​
118​
1320​
119​
1360​
120​
1400​
121​
1450​
122​
1500​
123​
1550​
124​
1600​
125​
1650​
126​
1700​
Those are tyre load ratings nothing to do with the wheel.
You need the wheel part number then ask the manufacturer, Fiat wheels normally have a prt number stamped on them.
daventess
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
Ordered one of these :
Gave the seller my requirements and he recommended it, so fingers crossed.
54,250
153,410
What was the load rating?
daventess
Jan 7, 2023
554
758
Bath, UK
Fleurette Wincester
Since Jan 2023
1,250kg. My rear axle rating is 2,500kg, so that should be ok?
edit - actually it's got 124R stamped on the side. Does that mean that's the max tyre load it could take? If so then it's more than that, about 1,600 if by lbs to kg convertion is right ...
They are 1,275 according to here :
though how authoritative that site is I don't know ...
WESTY66
6,063
14,991
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
I took mine off as I was told they were 1250kg🤷‍♂️( I now have 1450kg ones👍)
If you’re right about them being 1200 there’s an awful lot of carthago chic C lines with those wheels on driving round illegally🤷‍♂️😁
54,250
153,410
The Fiat Maxi chassis is 2400kg on the rear axle. I think the C line was on a Fiat with the Al-Ko as an option also I think the older heavy Al-Ko before the AMC was only 2400kg.
WESTY66
6,063
14,991
South Yorkshire
Mine was 2500kg
4,194
9,406
South Lincolnshire
Rapido 7065+
The spec says 1200kg so yet another minefield to negotiate with axle loads 🥴
