Apart from the fuses above the water heater where are the other fuses found. I have no electric heating! I have the Primero 301 with garage (1 Viewer)
Feb 13, 2022
Benimar
apart from the fuses in the garage([primero 301] where other fuse boards found. I have no electric heating. (W407 h)
Dec 6, 2011
11,639
25,584
South Wales
Coach built Adria
Hi and welcome.
Find your habitation battery charger and you will likely find the fuse board.
Oct 10, 2018
2,016
1,142
Bracklesham Bay, West Sussex
PVC
If W407h is a Truma fault code that is showing ? then it means there is no 230v supply (not on EHU or if on EHU , Truma Combi mains supply switch off at PSU ?) , or possibly the overheat button needs resetting on the Truma Combi unit or the 230v fuse is blown in the Truma Combi unit.
