haganap
- Dec 5, 2007
- 12,776
- 26,689
- Niesman+Bischoff 79e
- I'm an oldbie MH number 10
is it like all the other air con units I've had, only worth having on EHU?
I Wouldn't they are crap especially retro fitted, cold air is meant to drop down and cool, not be pumped up through a hot van first.I'm running out of accessories to install.
Therefore I am toying with the idea of installing under bench air con unit. Probably the freshwell 3000.
Does anyone have this?
also, how long would it run off lithium? or is it like all the other air con units I've had, only worth having on EHU?
tia.
Your not , I have the same Truma aventa compact plus fitted to my 7m Pilote it works a treat even on 6amp EHU and cools the van extremely well even in 100f temperatures.I must be in the minority as I’ve found the roof mounted aircon in our van to be a worthwhile addition. It’s a Truma Aventa unit factory installed in our Adria Compact, so not the biggest of vans but reasonably well insulated.
It pulled the temperatures down very well on full power while we were on EHU in Athens last year, but there’s another reason I want to run it from an inverter when I get around to fitting one. As we have the Truma blown air heating I can set that to ‘Vent’ only from the lower outlets. The aircon unit can work in conjunction with that and provide a high level ‘Vent’ function as well. It uses very little power in that mode compared to the full fat AC function, and we found it usually sufficient to keep us cool, especially at night.
Have you space to fit 2000w of solar on your roof? No me neither, so I don’t think it’s a practical proposition running aircon off batteries.
correct
Some one will be along to say that they have one and its great, good for them, but professionally we have fitted them and the customers have never been entirely happy, but we would have had no other option due to roof space and the customers "must have air con" for dog, wife, child etc
However, we got to the point where we simply refused to fit them
I had it factory fitted on a German van I ordered which was heavily insulated and very well built and the AC struggled anywhere warm in Europe. I could go into my mates van and feel chilly and the only way we could get any appreciable cooling was to have every blind closed, extra sun screen in addition to the factory fitted blinds and roof light covers, and we decided we didn't want to live in a black hole!
Roof air is fine, its underfloor ducted that is poor, even worse when trying to retro fit the ducting to the roof
I wouldn't have a camper without AC luckily I have a passion for RV's where AC is standard
I think EuroTrotters has ducted if I recall correctly
That is where we will disagree Eddie.
I have been in the RAC Industry for 35+ Years. So I have a bit of Knowledge of A/C Technical Background.
I fitted a Truma Saphir Compact Ducted to our 6.8m Hymer. Yes the Ducting of the system was a bit tricky and not straightforwards. But it works well enough for us.
We did not have enough under bench Space for the bigger, more powerful units. But adding things like Outside screen covers and closing blinds, the habitation area is very comfortable.
In Italy in August 2020, the temperature outside was pushing 40c. The temperature in the Motorhome was 26c. Foods like fruits, veg, bread and other larder foods stayed fresh outside of the fridge. You could sleep easy with the A/C on or off at night..
One of The problems as many will mention. Some People expect to be able to park in full sun, blinds open and feel like you are sat in a chiller. That is not how it will be and for health reasons, not how it should be. You really want to be aiming for your living space temperature to be no more than around 10c cooler than the outside temperature. So if its 38c out, 28c in is fine.
In the UK and Northern Hemisphere countries, it is suggested 21c is the preferred ambient A/C room Temperature. 22c for Southern European Countries.
A couple of years ago, Spanish authorities actually tried to force Hospitality and Shopping stores not to set their Climate systems below 27c in summer.
Anyway, back to the Underbench ducted. Works well if installed well if you follow a few simple rules.
Try to park in the shade or part shade
Don't expect it to run for long periods on battery and solar (unless you have a massive Solar array)
It will not cool as efficiently on the move running through Alternator/Battery/Solar, due to sun through cab windows etc
It must be ducted as high up in the Motorhome as possible. Truma's "comfort cooling" system will not work
Give it time to cool down from high ambient temperatures, several hours
Keep windows and doors closed, roof vents can be on vent
They don't like too much of an incline for long periods when in use
Also, put a filter of some kind under the van for the exhaust vent. Truma don't supply one and the impeller and chambers will fill up with crap otherwise.
I will try and post some photos or link a post from installation.
I would not want to be without it.
No the outlets have to be as high as possible, heat rises cool air falls.Ok, makes sense.
However, I was thinking of installing one of two ways so some info would be good.
First of all I think it's important to understand why I want it installed. It's not really to cool the van persay but to have a cool air outlet for our 8 stone hairy beast. When driving, like any dog, she can find the cab aircon outlet and position herself there with no issue.
So my plan was to do one of two things.
Underbench the unit in a space I have, with an outlet/duct pretty much next to installation as this is pretty much perfect for where it needs to vent in to the lounge. Then was to add a duct and travel to the rear of the van to get some cooling done in the bedroom. (gets hot in there sometimes )
Or my second thought was to run it straight in to the heating duct? Then place a shut off in the duct somewhere, my thought then would be that it would cool through the heating duct? Sounds like that's not a good idea though.
seems to be you have to duct high in to the van, so food for thought there then.
don't put it through heating ducts, that is Truma Comfort and is rubbishOk, makes sense.
you dont need to seal the window area on some types, check out Cool My Camper ......im finding this discussion fasinating - so what about the window aircons i see sometimes. ? as far as i can see you need to seal the window area - but the concept seems reasonable, with add on solar panals on the floor and sitting in the shade ?
and how does this stack up to a humble omnivent ?
More suited to stationery use. But that’s not to say it cannot be adaptedim finding this discussion fasinating - so what about the window aircons i see sometimes. ? as far as i can see you need to seal the window area - but the concept seems reasonable, with add on solar panals on the floor and sitting in the shade ?
I have a freshjet 2200 on the roof as well, but mine isn't connected to the batteries as I didn't think it would be practical, it can also blow warm air in the winter as well which is useful, the air is not hot but a little warmer than ambient but over a short period of time is quite effective, handy if you have under floor heating which takes a little time to warm the van up.
