Another case of broken Central Locking (1 Viewer)
OldCodger
861
202,542
Surrey, UK
Carthago I 143 LE
Since 2016
I’ve just bought a new to me Carthago C-tourer 148 LE. 2019 on the Ducato 290 chassis. 2.3/130BHP. It was a private purchase
I may a few questions for the group :whistle2:
My current problem is the central locking isn’t working. The key seems to talk to the Tracker/Alarm as I hear the set/unset beeps and the read light on the lock button comes on. I also hear a faint click from somewhere inside the dash.
Neither the hab nor the cab door operate.
The lock button doesn’t work either (but I do hear that faint click)
I’ve tried the various things recommend by t’internet (start engine a few times, disconnect cab battery for a few minutes) to no effect. I’ve checked a few fuses as well.
Any suggestions. I’m moderately teccy and have meter /ODB readers etc but they have yielded nothing so far.
nickq
170
251
berkshire
Since 2011
Check if you have those spring loaded contact points in the doors. Give them a clean and make sure they still line up in case the door dropped. Bit odd that it would be both doors though so this may not help but did on one of mine.
OldCodger
OldCodger
861
202,542
Surrey, UK
Carthago I 143 LE
Since 2016
No visible door contacts ( or wiring conduit!) on hab door. Cab door has a conduit. No obvious damage anywhere
Were the c-tourers fitted with central locking?
TheBig1
17,649
43,469
There is an aerial under the dash to pick up the remote signal. This is different to the alarm receiver
Minxy
32,700
66,735
E Yorks
Carthago Compactline
Our 2019 Compactline doesn't have central locking.
Minxy
32,700
66,735
E Yorks
Hmmm. Does the cab door lock/unlock?
Only with a key, we have one with the grey sides, AFAIK it's the later ones with white sides that have it as standard so if yours is the same as ours it might not have it.
Minxy
32,700
66,735
E Yorks
Central locking is good but the downside is that when you unlock it usually means both have and cab doors are unsecured whereas with manual locking only the door we have unlocked is so when on an aire and want to open the hab door we don't have to prat around ensuring the cab door is still secured.
Sep 10, 2017
651
726
North Brum
I or T model? Some T models retain the locking function on the cab doors but not on the hab or lockers.
Our 2019 149 LE Intergrated doesn't have have central locking either. At first it annoyed me and then thinking it through it is probably best it hasn't got. If parked up in a less than good area like parts of Brum (I can say that I live there) then unlocking all the doors means some little scrote can have access to the cab or the garage on the offside whilst you are on the hab door side.
We fitted security locks shortly after purchase to all doors and lockers when I found out how "less than good" the OEM plastic ones are so C/L would be a waste of money for us now.
Cross post with Minxy.
Dec 19, 2020
3,477
9,225
The salty bit of Hampshire
Since 2017
My 2016 Compactline has central locking. Mostly I just use a key for the hab door and don't use the central locking once set upon arrival at site.
