Alde heating problem (1 Viewer)
Aug 11, 2019
432
1,565
North Pembrokeshire
Knaus Sun TI 700
A newbie
Thanks for posting this. Particularly the solution. We have all been there. The learning curve is steep but there are always knowledgeable people on here willing to help.
ctc
Oct 12, 2015
1,526
2,559
Crowle
Hymer b680
New
I’ll check the amp monitor setting, but the electric icon was lit and we were only set at 2KW on a 16A EHU with no appliances other than the fridge being used.
Why set to 2kw? The Alde system does that itself when it nears set temperature. We don't use day and night settings since we are there at night just reduce the temperature to suit the conditions. When there is only 10amps available our system copes very well whatever the weather.
Should have read your last post.
C
CRD
Apr 15, 2021
153
179
Devon, UK
Adria Matrix 670 DL
3 Years
We don’t have an amp monitor installed. I didn’t know that then. The Alde system seems very capable at adjusting current usage dynamically and only using the minimum required, even if set to 3KW
Apr 26, 2015
2,793
6,947
Ottershaw
Hymer S820
First motorhome May 2021
Just as an aside, I have a Truma Aquatherm in my van, this was a short lived amalgamation between Aldi using their radiators, pipework and expansion tank with a Truma boiler, even when external temperatures are down to zero I don't need to set it to 2 Kwh's, 1Kwh is sufficient to keep the interior around 23⁰C does anyone with the same system experience the same or am I just lucky?
ceejayt
3,226
5,844
Stamford Bridge - Yorkshire
RS Elysian A Class
Since 2004
I think it depends
On size can and insulation plenty
Will be better and worse
funflair
19,428
30,576
Guisborough
MORELO palace
since 2012
The saga continued with an embarrassing outcome……!
After following the instructions from Alde support and rebooting the system, I set up the temperature to 17 degrees overnight (not using night mode) and hoped that it would be working well the next morning.
Nope!
Indoor temperature was 15 degrees, so it hadn’t maintained the temperature over night, again. Following the next part of the instructions from Alde support, I then carefully took off the Alde panel cover, undid the retaining screws and took out the panel to see if a cable was connected to the JP3 port from the adria control panel.
There wasn’t a cable so I put it all back together again and thought about phoning the dealer to log a warranty claim to get the error investigated.
Then it dawned on us that I was turning the control panel off at night, not realising that it also turned off the heating system!! We hadn’t been told about that and assumed that the panel on/off switch just controlled the panel and not the entire system.
So last night I kept the panel turned on, but dimmed as low as possible, and this morning the indoor temperature was exactly at the temp I had set in the evening. It worked perfectly!
This explained why temperature control was working during the day, but not at night.
The system is working fine, shame about the user though!
How embarrassing to have jumped through all these hoops, but we’ve only had this van for four days, and I guess our handover wasn’t as comprehensive as it should have been.
Thanks, everyone, for all your help and advice.
Good on you for owning up and updating us ;) pleased you are sorted.
