Agh help! (1 Viewer)
Dec 8, 2018
46
16
Bessacarr e435
1 year
Hey peeps,
I have a bessacarr e435 and the water isn't pumping properly.
If I turn on with the red switch it pumps for ever, but taps and shower don't produce any water.
Found a yellow switch at hot water tank and tried in all 3 positions.
Nada.....any ideas what is happening?
TIA
GEORGE.
Apr 22, 2018
6,827
12,599
Herts.
Adria Coral lowline
is there water in the tank?
is water appearing under the van when the pump is running?
is possible that the pipes are frozen?
have you previously drained the system?
movan
21,492
120,753
Moving around
Burstner
since07
Don't know your van, but like denise and Joe say, it was bloomin cold last night... Could the automatic dump have kicked in?
Jul 24, 2009
4,335
105,223
South Yorkshire
Since 1999
Does it have a low temp dump valve on the boiler? If it has it's a fair bet that it has opened to protect the boiler from frost. Someone will be along shortly with a picture showing what it looks like and how to close it.
Apr 22, 2018
6,827
12,599
Herts.
Adria Coral lowline
Check this, if you have one.
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
Iā€™m guessing that is your boiler drain valve youā€™ve opened....if youā€™ve moved it.
Did it look something like this
If so your probably either out of water or frozen....šŸ˜¢
Apr 9, 2018
8,703
45,125
Worcestershire
Bailey Adamo 75-4t
March 2018
Our van has three drains. One that drains the taps and pipes. Above pic is the one.
An auto dump on the boiler that opens at low temperatures automatically. Looks like a black curved box with a blue knob on top and blue push button on the side.
Also, a knob on the top of the tank that drains the main tank.
Remember that it takes some time to fill the boiler when you run the hot taps and takes about 10 litres depending on your system.
george mcneill
Dec 8, 2018
46
16
Bessacarr e435
1 year
Need to put yellow drain valve switch in vertical position again.....the water was coming out of disconnected pipe at toilet flush, inside the cupboard where you change the toilet box.
Follow the gravity.......thanks to all, Georgio
