Advice on this RV £6k, no MOT and potential damp (1 Viewer)
JacobsMess
5
18
just looking
So looking to get a motorhome to travel to Norway for a few months later this year. I've found something local that is downplated to 3.5T so I can drive it on my car license, but they want £6k, it hasn't had MOT for 3 years (200miles since the last one) and has some rot by the sounds of it. would you advise to move on or try to negotiate price down?
I'm handy at DIY and construction/mechanics on simple engines but would obviously like to avoid spending more money than necessary for a big project. How easy are body panels to replace?
Riverbankannie
10,610
62,041
Bristol
IH 630 RL PVC
It is worth what someone is prepared to pay for it whatever state it is in.
However some points to consider
It looks like it would struggle to come in under 3500 especially if you are not travelling on your own. You need to know what it weighs now, the 3500 is for fully loaded and on the road including occupants, not just what it weighed empty when down plated.
Getting repairs done in Norway is very very expensive as I think jumar found out so you would need to know that it is in excellent mechanical condition.
I’ll let someone else discuss damp issues.
Dec 24, 2014
9,273
47,839
Hurstpierpoint. Mid Sussex.
Compass Navigator
Can't help with the panels.
Its MOT record has been quite good but at the last one lots of corrosion on underside which won't have improved (and many other parts will need attention) through standing unused (outside?) for the past 3 years.:
Date tested7 October 2016​
PASS​
Mileage60,667 miles​
MOT test number8306 4901 4737​
Test location​
View test location
Expiry date6 October 2017​
Advisory notice item(s)​
  • LOTS OF SURFACE CORROSION ON UNDERSIDE
What are advisories?
Date tested30 September 2016​
FAIL​
Mileage60,649 miles​
MOT test number1475 4306 1850​
Test location​
View test location
Reason(s) for failure​
  • Direction indicators flashing more than 120 times a minute all (1.4.A.2g)
What are failures?
Date tested15 June 2012​
PASS​
Mileage59,359 miles​
MOT test number3399 5766 2132​
Test location​
View test location
Expiry date14 June 2013​
FAIL​
MOT test number9650 7776 2126​
Test location​
View test location
  • Nearside Stop lamp not working (1.2.1b)
  • Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
  • Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
What are failures?
Date tested15 June 2011​
PASS​
Mileage58,242 miles​
MOT test number3890 5616 1111​
Test location​
View test location
Expiry date14 June 2012​
Date tested13 June 2011​
FAIL​
MOT test number8854 0436 1146​
Test location​
View test location
  • Offside Front position lamp(s) not working (1.1.A.3b)
  • Offside Upper Stop lamp not working (1.2.1b)
What are failures?
Date tested1 June 2010​
PASS​
Mileage56,106 miles​
MOT test number8734 4205 0133​
Test location​
View test location
Expiry date6 June 2011​
Date tested27 May 2009​
PASS​
Mileage54,217 miles​
MOT test number2701 6784 9457​
Test location​
View test location
Expiry date6 June 2010​
FAIL​
MOT test number2633 0774 9414​
Test location​
View test location
  • Offside Rear fog lamp not working (1.3.2b)
What are failures?
Date tested2 June 2008​
PASS​
Mileage52,760 miles​
MOT test number2118 4455 8422​
Test location​
View test location
Expiry date6 June 2009​
FAIL​
MOT test number9448 9475 8192​
Test location​
View test location
  • Service brake: efficiency below requirements (3.7.B.7)
What are failures?
Date tested7 June 2007​
PASS​
Mileage50,667 miles​
MOT test number8139 0805 7157​
Test location​
View test location
Expiry date6 June 2008​
Date tested23 May 2006​
PASS​
Mileage48,630 miles​
MOT test number2819 6374 6136​
Test location​
View test location
Expiry date22 May 2007​
  • Offside Inner Rear Tyre worn close to the legal limit (4.1.E.1)
Outstanding vehicle recalls​
Check if ROCKWOOD M977RKG has outstanding recalls
Support links​
Open Government Licence
All content is available under the Open Government Licence v3.0, except where otherwise stated
© Crown copyright
946
3,151
Totton
Bailey Autograph 745
Since Sept 2020.
As above, I'd be wary of the 3.5T. If that's without food and clothes in the cupboards, no water in the fresh or waste tanks, no gas and no passengers (or any one of them) you'll be driving without a licence once you load it, and that will very likely knock-on to the validity of your insurance.
53,736
151,175
:welco:
Looking at the photo no way is that drivable at 3.5t more like 6 - 7t.
A vehicle standing around for 3 years is likely to have all sorts of mechanical problems and may need a few grand spending on it.
Most damp problems are fixable if you are good at DIY but if you need to get a workshop involved you are talking thousands.
What's it worth in good nick? If it would be around £20k probably worth a punt.
The Coops
1,828
34,612
The Fylde
Adria Compact DL
Yes, thank you
Its over 25 years old and an import you are going to struggle with spares and breakdown insurance plus emissions in Low Zones , how bad is the damp? Not a project I would consider
jumar
3,801
11,704
Spain
Hymer Tramp
Since 1994
Yep...eyes still watering after experiencing two breakdowns in Norway...
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
If I understand your question correctly, replacement external body panels will not exist, you will have to work with what you have got. Possibly built upon a Chevrolet P30 chassis, with the 6.5 litre turbocharged diesel engine, the gross weight would be an issue at 3.5t, remember one gallon of water weighs 4.5kg :gum:
Feb 16, 2013
19,785
52,217
uttoxeter
ambulance conversion
50 years
External panels presumably alloy so shouldn't be a problem, just a good clean, but that then is the least of your problems, the 3.5 ton is really a laugh, no way is that going to work, and the underneath and mechanicals is going to be obsolete, and also the inside of damp has got in are going to be rotton :Eeek:
Up to you but if you are thinking of going on your own do you really need something this big anyway.?
old-mo
Extra Special
16,344
93,719
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
As said if that has been down plated that much, doubt there is enough payload for a driver....
Who ever down plated must have had a nice back hander...
I would think that bare bones straight from the factory it would weigh at least 5 tons..
To be honest I would not think about buying it.. and I have bought some sheds in my time..:crying1:
You can often pick up or some one will know of one that may suit you or be a better bet than that one.. on our sister site =
And do you have the license to drive over 3.5 tons..?
Good luck in your venture what ever road you take... (y)
Tombola
4,865
15,799
Merseyside
Rapido 8094DF
There is one permanent on a site I visit in North Wales similar age, thats only good for permanent living and thats what he does, lives in it full time.
Never seen him even start it.
Tombola
4,865
15,799
Merseyside
Rapido 8094DF
It what way is that useful ?
Comments like this put new members off asking questions 👎🏻
Must say initially i almost thought similar , in the way that WHOAAAA thats a brave person who wants to get that and shoot off to Norway...whats the catch
Swifter
3,917
9,059
Herefordshire, UK
Since 2019
Must say initially i thought similar , in the way that WHOAAAA thats a brave person who wants to get that and shot off to Norway
Yes but imagine how you would feel if you were new to a forum and were asking a genuine question . The guy only joined as a free member this morning . It’s nice to see the majority of the advice has been honest and genuine .
Tombola
4,865
15,799
Merseyside
Rapido 8094DF
Oh yes, of course I agree ( and also seen Jims post regarding same) and which is why I didnt pose the same question, just saying it initially raised my eye brows as WOW...in THAT ?
Feb 27, 2011
14,792
76,448
Wind up??
Feb 27, 2011
14,792
76,448
I can't see that getting down to 3.5T even totally empty with the interior stripped out :Eeek:
I think there may have been a misunderstanding there?
Oct 14, 2007
4,009
6,285
Rochester
Auto-Trail Mohawk
16 fun filled years
The main concern would be the 3.5T as others have pointed out it's very doubtful. This has money pit written all over it in my opinion.
Best of luck
Apr 13, 2012
5,553
18,814
Mobilvetta Euroyacht
1996, then break 'til 2011
I'd always check the MOT history
This one has done 12,000 miles in 14 years, 1000 in the last 4 up to 2016
MOT 2016 advisory, lots of surface corrosion underneath
