A wasp was flying along at 10 mph when........ (2 Viewers)
Dec 24, 2014
9,318
48,079
Hurstpierpoint. Mid Sussex.
Compass Navigator
........it became squashed on the windscreen of a train coming head-on out of a tunnel at 60mph.
At the moment before the direction of the wasp reversed through 180 degrees when it became squashed on the train's windscreen it must have been stationary for a fraction of a moment, but the train didn't stop................................ :unsure:
meanders
Funster - Life Member
2,717
8,877
Ipswich, Suffolk
Good grief where did you dig that up from? Had that set only with a fly rather than a wasp at college 50 odd years ago.
The answer is in the relative mass. If the wasp weighed even 1% of the train mass, a tiny deceleration would be detectable. I guess with modern day instrumentation or laser scanning of the screen, a tiny deflection or flex might be measurable on the screen, but why would you bother.
Feb 16, 2013
19,830
52,438
uttoxeter
ambulance conversion
50 years
It used to be said that steam rollers were kept in service long after diesel rollers came in because they could go from forwards to reverse in an instant and vice versa, so not leaving ridges in the tarmac when rolling whereas diesel had to stop and change gear while sinking in.
Apr 9, 2018
8,753
45,563
Worcestershire
Bailey Adamo 75-4t
March 2018
So if a cage full of pigeons being transported by plane escape and start to fly around does the plane weigh any more or less?
No. Because the weight of the birds is being taken by the air in the plane, which in turn is borne by the plane.
Apr 9, 2018
8,753
45,563
Worcestershire
Bailey Adamo 75-4t
March 2018
They both stopped on impact for a fraction of a nano-second.
Stands to reason, if the fly stopped so did the train
Surely not. The inertia of the train far outweighs that of the wasp. The train would lose some speed but not much. If the train stopped momentarily then it would have to accelerate back to speed instantaneously, which it canā€™t.
Tombola
4,915
16,001
Merseyside
Rapido 8094DF
If tree falls in the woods and no one was around ........???
Spriddler
Dec 24, 2014
9,318
48,079
Compass Navigator
Much the same as if you're over payload weight when stopped in the m/h at a checkpoint. It would make no difference if you were to drink all of the booze on board........ but fun nevertheless.
Tombola
4,915
16,001
Merseyside
Rapido 8094DF
Still makes a noise.... Sound waves will still be made.
but it isnt sound until the wave reaches an eardrum and is turned into audio ?
OR IS IT !!!!!! :roflmto:
11,963
16,582
Doesn't move. There are no forces acting on it.
There are. The air within the vehicle has mass and therefor momentum. It will move forwards to displace the less dense balloon. The visible effect will be the balloon moving towards the rear. More information here:
Tombola
4,915
16,001
Merseyside
Rapido 8094DF
If sound waves are present so is noise.... Can't have one without the other.
If thunder is created and a person who is completely deaf cant hear it because his / her ear hasnt turned the waves into sound then there is no sound :)
Apr 9, 2018
8,753
45,563
Worcestershire
Bailey Adamo 75-4t
March 2018
So does the free air in the car, the air will reduce velocity at the same rate as the car... And the balloon is floating in that air.
I think the air will continue to travel, as will the balloon because they have mass and hence kinetic energy. The air will increase in pressure in the front of the car and reduce in the rear until it is all equalised . The balloon will continue to travel until air resistance absorbs what small kinetic energy it has.
