Likely because 3g is being phased out so he'lll need 4g minimum.a) Why are you replacing the Huawei ?
The battery is totally done and needs to be plugged into the power all the time, and its that long in the tooth that i don't think its worth buying a replacement battery for. plus i "THINK" the mifi is only 3g or is it 4g compatablea) Why are you replacing the Huawei ?
b) I just bought the ZTE MF910 off Aliexpress - delivered in 15 days, £40 tracked
https://www.aliexpress.com/item/4001273136118.html?spm=a2g0o.productlist.0.0.7c817280SoQoOs&algo_pvid=434302ef-60b5-4aca-be7d-5547be819480&algo_exp_id=434302ef-60b5-4aca-be7d-5547be819480-1&pdp_ext_f={"sku_id":"10000015555510426"}&pdp_npi=1@dis|GBP||37.02|||||@0b0a050116510798524158780e5d76|10000015555510426|sea&aff_fcid=814d9b8cf32f49b0a6290077487d9418-1654607014309-07645-_A7XBIB&tt=CPS_NORMAL&aff_fsk=_A7XBIB&aff_platform=portals-tool&sk=_A7XBIB&aff_trace_key=814d9b8cf32f49b0a6290077487d9418-1654607014309-07645-_A7XBIB&terminal_id=51c3f545b211424391d06e16754bbdef&afSmartRedirect=y
HW Router store, seems to have mifi in lots of price ranges
yar i think atm i am actually using converter leads from my aerial to the current MiFi.Bart, you can get converters for the aerial connectors if needs be.
Our old mifi looks just like yours but we found the TS9 connectors were too loose and used to fall out occasionally.So its time to replace our 3g Huawei E5372 mifi unit , as we have an external 4g antenna on the van i would like to get a replacement MIFI unit with what i think are TS9 connections on it ?? , the same as our current mifi unit.
not looking to spend more than £100 ideallyView attachment 627043
i to am pretty sure its 3g only ,, but yet when i put my phone sim in it shows this. so im confused is it 4g compatable.Likely because 3g is being phased out so he'lll need 4g minimum.
atm im using screw on to sm9 leads ,, what mifi did you go for that has screw on connectorsOur old mifi looks just like yours but we found the TS9 connectors were too loose and used to fall out occasionally.
Decided to go with a router with SMA ports that screw on.
I think it's 4gi to am pretty sure its 3g only ,, but yet when i put my phone sim in it shows this. so im confused is it 4g compatable
Just did some more googling Mel and came up with this :I think it's 4g
Huawei E5372 Review | Expert Reviews
The E5372's LED display gives away too much information, but we like its performance and featureswww.expertreviews.co.uk
Most only do 150, there are some that do 300 but they are more expensive and in any case it's still an 'up to' figure.Just did some more googling Mel and came up with this :
The Huawei E5372 modem is already known by many operators: it offers 2G GSM, 3G UMTS and 4G LTE (Category 4 of up to 150 megabits per second for download).
and then this
So what's the difference between 4G and LTE, and is 4G or LTE better? In short, 4G offers a much faster speed, more stability and access to a larger variety of online activities. LTE is a half-point between 3G and 4G, so its performance suffers compared to the fourth generation
so seems its like a step between 3 and 4g
or edit a slower speed of 4g 150 megabits
YesI have unlimited data on my 3 network with my mobile for which I pay 3 monthly.
Is it possible to swap my 3 sim card and put it in a unit like the ZTE MF910 and swap it back to my phone as and when I wish - that way I can avoid paying for another mobile network?
I connect to the hotspot using the WiFi on my phone and that works fine, just won't get SMS, but I mostly use whatsappYes
Hurdle might be the size of sim your phone wants and the size of sim your mifi wants - but this is easily overcome.
Would it not be easier to use your phone as a hotspot, and tether your devices?
There are some downsides to this approach.
If your three sim is in your mifi - what is in the phone?
What about calls?I connect to the hotspot using the WiFi on my phone and that works fine, just won't get SMS, but I mostly use whatsapp
For me not much of an issue as most of my calls (if I ever get any!) Comes through WhatsApp. I would mostly only use this method in the evenings so we can get Netflix. Plus my wife still has her phone on her. But yes you are right you won't receive calls.What about calls?
Unlimited 3 sim, unless you are roaming , in which case its 12 GB per billing period, or monthYes
