360 degree birds eye camera (2 Viewers)
Apr 17, 2022
27
23
Cadwell Park Circuit, Cawkwell, Louth, UK
burstner argos
Morning all,
I have a two camera rear view mirror setup, which is great for general driving, It automatically switches to second camera when reversing but in truth it’s not a lot of use as you can’t actually see the corners of the van , maybe needs a wider angle lens? ( the bike rack doesn’t help either) I’ve just seen these 360 degree systems and wondered if anyone has any experience with them?
many thanks bob
funflair
19,365
30,302
Guisborough
MORELO palace
since 2012
Indeed we do (y) we have the Camos 360 HD digital system and I have just added 4 channel recording to it as well (I think you can get recording built into one unit now as like everything ours is trhe older version), it's great for parking and maneuvering as you can see the corners in the overhead view, when you indicate to change lanes etc it shifts to give more of that lane view in the overhead, reversing I can get to within a couple of inches of obstacles.
bobupanddown
Apr 17, 2022
27
23
burstner argos
Thanks very much for taking the time to respond, that looks and sounds great, i will be looking at fitting something like this , I do quite a bit on my own and am always in and out the truck when reversing near obstacles
AlunandFelicie
613
7,446
Burstner lyseo time
Absolutely would not be without my camos setup. Worth every penny and SWMBO appreciates not being asked to hop out and help with any manoeuvres
Same here great system that covers all the blind spots👍
I did wonder if in France they would negate the need for’angles mort’ badges as there are no blind spots?
poacher
114
242
Looks like a great bit of kit, can they be used when parked up to see if there are any scroats about?
Yes - some 'tweaking' of connections necessary
(Ours - with its recorder runs 24/7 - beware of power consumption if running 24/7 and not large batteried or on EHU - "every little matters" ;);))
81
118
Suffolk, UK
Van Conversion
10 years
My rear view camera stopped working recently so was thinking of upgrading to one of these systems too as they look really impressive- but I think nearly £2k is going to be hard to justify. I wonder how the cheaper systems available on Amazon for example compare. An interesting bit of research for the next few days..
Upvote 1
AlunandFelicie
613
7,446
Burstner lyseo time
My rear view camera stopped working recently so was thinking of upgrading to one of these systems too as they look really impressive- but I think nearly £2k is going to be hard to justify. I wonder if there is cheaper solution than the Camos.
There are but it’s a matter of trust ,would you feel safe with a £200 Chinesium system bought of EBay?
2,697
2,158
Northumberland
Hymer A Class
Since 2019
Considering the value of what you are trying to safeguard, £2.5k is a reasonable investment IMHO. We are going to sort out getting the CAMOS 360⁰ HD system next week.
Thanks to all posters for their honest opinions.
81
118
Suffolk, UK
Van Conversion
10 years
I wonder if you can get the same sort of setup with home CCTV too - i.e. Something to take in the feeds from various cameras around the house perimeter and merge them into a 360 degree overhead view. If nothing else it would be a really good way of highlighting any blindspots.
4,959
17,301
Todmorden
Van conversion
FUNSTER in a PVC
Don’t think they have zoom lenses on them, so the further you travel from home, the worse the picture gets, and if you turn a corner 🤪🤪
funflair
19,365
30,302
Guisborough
MORELO palace
since 2012
Here's ours being fitted. We also had a hard drive fitted to store the footage.
I had our screens fitted portrait instead of landscape on the basis that the Motorhome is long and skinny and would fit the portrait format better, that way I don't mess about with different views and when I select reverse the rear image is behind the 360 view, I say screens as in we had two fitted which was the first time that they had done it that way so had a to make up a wiring loom for it, if you don't ask you don't get, the guy fitting it was chuffed with the result and did a few more the same after ours.
Upvote 1
Dec 13, 2019
2,697
2,158
Northumberland
Hymer A Class
Since 2019
We have decided to go for one as, having looked them up on the CAMC website, we get 10% discount as members. That should bring it in at just on 2k for the top end model.
5,461
10,198
Birmingham, UK
A-Class
I'm thinking of getting a set fitted as my reversing camera is failing. I think they are primarily for manoeuvring. They're probably less good for incident recording number plates and pretty poor for security, other than maybe as a deterrent. The cameras are very wide angle and fish eyed.
2,826
14,472
Mid Bedfordshire
RS Endeavour
Just a tad..
Is this £2k installed? I’m assuming it’s a fully ‘run’ hidden cable install? There is quite a bit of internal deconstruction needed to properly run cable in my Motorhome.
Upvote 1
Feb 24, 2013
13,083
101,459
Bolsover, Derbyshire
Hymer S800
not long enough
I wrote this when we fitted ours , amazed how long ago it was
I agree the long distance view particularly backwards isn’t great, but mirrors are there for that , until close up
We had to have a new monitor after 3 years, only cost £120 and easily fitted by me 🤔👍
Big issue I have is I have to reverse into a walled corner at home to turn round , the camera struggles to pick out both corners at same time
Apart from that I like it, I wouldn’t bother with the very dated recording option we bought, only downloaded once following an accident ahead of us, even though only 100 feet away it didn’t show enough detail. But it would have been good better had we actually been involved in the accident I think
13,083
101,459
Hymer S800
not long enough
Mine took a day and a half on my drive for two hard working Eastern European technicians , very careful and competent 👍
2,697
2,158
Northumberland
Hymer A Class
Since 2019
I need to speak to them tomorrow, but yes, that is what I believe from the dummy online order I created earlier. £2,340 before discount.
I will post the outcome
2,697
2,158
Northumberland
Hymer A Class
Since 2019
I will keep our Nextbase dashcam as it is date, time, location and speed stamped. It has saved me a fortune on two occasions by proving accidents I was involved in were 100% not my fault.
