- Feb 14, 2021
- 3,659
- 7,896
- Burstner Lyseo 727G
- 19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
It’s the element. Still waiting on parts…
I got that one wrong then.It’s the element. Still waiting on parts…
Just for future reference, was that reading of 1 in picture 4 of post #24 correct? I was a bit suspicious that there were no other figures. I should have noticed it was on the 2000 ohm range, not the 200. What reading do you get when the meter is on the 200 ohm range but the probes aren't touching anything?The 1 ohm reading looks OK to me. It's not very accurate (more than 0.5 but less than 1.5) but if there was a fault it would read 0 or OVLD (very high resistance). For slightly better accuracy you could try on the 200 range. Before you measure, touch the probes together to measure the probe lead resistance, and subtract it from the element reading. I'd expect about 1.4 for a 100 watt element, 0.7 for a 200 watt element.
For example, if touching the probes shows 0.3 ohms, and the element reading is 1.0 ohms, then the true element resistance is 0.7 ohms.
Oh my goodness - 7 months!!
Hi, had similar issue all fuses ok from engine compartment back to fridge relay behind external vent area. Also fuses in domestic fuse / MCB consumer unit. Turned out to be changeover relay in engine compartment not sending power when required.
Generous offer. I think I need to locate this relay first. Pic below shows a 30 amp fuse in the starter battery well. It's got a light red(slightly pink) wire and a black/red wire. I cannot see where it goes. In addition there is a 50 amp and a 20 amp fuse.Yes, I have a Fiat Ducato base vehicle on a Swift Kontiki. There’s a 10mn brown cable on a 30a fuse feeding the relay. I googled Dommetic fridge change over relay and they’re very expensive, so I just bought a pack of 5 terminal relays for about £5 thinking it would just blow but it has been working perfectly for over a year. I still have the remaining 4 would send one to you if it’s the same?
See the black cover with the 2 nuts holding it down, mine are under that.
Including the fridge relay !VXman your relays are within the EBL 119 there is information on the Schaudt system you have which may help at www.aandncaravanservices.co.uk
No the main fuse box is passenger side glove box area in cab. You probably need to take the exterior fridge vent off and see what colour/ size of wire is feeding the 12v side. Then find that wire within engine bay, that should lead you to the supply and relay?Mine doesn't have anything like that. Is that your main Ducato Fuse box? I just have a fuse box behind the passenger side headlamp - tucked under a little. Lots of fuses and relays but no way of telling if any are for the fridge.
The fridge 12V element should be powered from the starter battery when the engine is running. It usually has a 20A fuse, near the starter battery. However the fridge relay is triggered by the D+ signal, which on the EBL119 wiring diagram has a 2A fuse. It doesn't say where it is, except that it is not one of the EBL fuses on the front panel, and is outside the EBL somewhere. So it could be mounted near the leisure battery, for convenience since there are already a couple of fuses there already.So one or both of those fuses is clearly related to the fridge changeover. Everyone has been saying the fridge is linked to the starter battery. 'confused'
If there is no D+ signal (if for example you have pulled the fuse) then the fridge relay and the split charge relay will both stop working. The D+ signal should be about 12V when the engine is running, and near zero when the engine is stopped.
Yes, aware of all of this and all that is ok. Just not cooling on gas , even though there is a good flame.Be aware that on most/many modern fridges.
They only work on 12v off the battery when the engine is running.
They only work on electricity, 240v, when the EHU is plugged into the mains.
When the engine is stopped, and there is no 240v mains electricity, then they revert to gas.
There is a 15 minute wait after the engine has been stopped before the pilot light will ignite and the gas flows.
This is to ensure that if you stop for fuel, the pilot light does not come on in a fuel station!
(Also the fridge will only work on gas, if there is gas in the bottle and the valve(s) have been opened!)
I'm sure someone will be along soon to say their DIY fitted fridge does not work that way ......
Most German Vans the fridge will run of the hab battery when battery is selected on the fridge. Every van we have had does that.Be aware that on most/many modern fridges.
The fact that it works OK on 240V and 12V indicates that the cooling circuit is working fine. Anything that applies the correct amount of heat (about 200W) in the correct area of the cooling circuit will cause the cooling to work.
So maybe the flame is present but is too small to have the required effect. That can be a number of causes, mostly resolved by cleaning and servicing that bit of the fridge, including the flue.
