247 w (4 Viewers)
ShiftZZ
21,383
84,583
Dark Side of the Moon
I have two 80 w solar panels on the roof of the van. So in theory on the equator mid day no cloud I should in theory get 160w MAX, with me so far?
Right, my meter, has a different slant on life...
See below.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
I may be wrong Hilda but i think that is around 1.5 amp @ 230v which is about right on a cloudy day!
I have two 80 watt panels and the best i have had is 9 amp in full sun when it is directly overhead!
DBK
18,033
48,138
Plympton, Devon
PVC, Murvi Morocco
Do you get any readings at night and/or does the reading fluctuate if the sun goes behind a cloud? The reason for asking is to check the meter is wired correctly. It might be the readings are showing current coming from the battery not what the sun is putting in to it. A near 18A charging current could also be frying the batteries. Also, what is switched on in the MH to be drawing this current?
ShiftZZ
ShiftZZ
21,383
84,583
I have no idea, DBK. I may take it to my repair guy and get it checked out, another cockup by Mr X...
John & Joan
1,425
774
Darlington
10 years this time
I have 240w of Solar and at the beginning of the month I got a peak amp reading of 19.25 Total Ah input for the day was 79.7
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
With my regulator thingy you can reset it.
I am definitely no expert apart from fitting panels to two of my self builds, but I suspect your controller needs to have you push some buttons to get it to give you correct readings.
I have to set mine to the correct voltage and type of battery etc.
Do you have instructions?
JJ :cool:
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
I would have thought 14 amp max from 160 watt
We have 280 watt one old 100 watt and a new 180 watt panels
And even in morocco it never went above 18 amp in full sun Even though calcs say it should do 23 amps
I think:whistle:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
We have 400w and I have never seen it above about 20A max in normal European sunshine. This is 240w (20x12) . Perhaps I should clean the panels.
