230v TV with Inverter? (1 Viewer)
dutts303
136
30
Devon
Chausson Flash 03
Since 2019
Hi,
I've been quite put off by the cost of 12v tvs (for brands I've never heard of with broadly very mixed reviews) and wondered if using an inverter like this (Amazon product ASIN B076P9PGX3) with a normal small 20inch 230v tv would work as long as the power consumption was below 300W?
Does anyone do this? Is this even possible? Any downsides?
Rich
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
We did this in a previous van on a small inverter we bought from Lidl or ALDI.
No problems whatsoever, although ensure you have a couple of batteries and a solar panel if off ehu to be on the safe side if watching more than an hour or two.
tonka
10,838
21,556
Cannock, Staffs
A class Burstner 800
Since 2000
YES.. Works fine..
In my last van had a cheap Asda mains TV and used a 150w inverter. If you look on the back of the TV there will be a label and it will state the wattage. New LED tv's use very little power, maybe 25-30 watts. (y)
scotjimland
2,375
10,327
A Woosh bang
Yes doable, however, inverters are not 100% efficient,
so it it will use slightly more power than a 12v TV
A lot of 240v 20" TVs are actually 12vdc using a power converter on the cable..
If buying a new TV worth checking this before deciding on buying an inverter .. they don't advertise them as being 12v
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
Yes we use a 230v Samsung TV on a 200w psw inverter. The set up uses about 0.2 amps more than it would otherwise.
Get a small good quality inverter with low standby current like the Studer AJ series (y)
May 6, 2010
547
638
Doncaster
April 2010
We have a 300w pure sine invertor runs 32” Sony smart TV, Sky box & a soundbar drawing about 4amps also runs the 27” TV in the bedroom
Sep 17, 2017
5,516
10,295
Birmingham, UK
A-Class
Using an invertor opens up the choice of TVs you can use and the latest flat screens which are pretty efficient. However, power usage is related to the area of the screen. 32" is quite a lot of screen to light. 4 amps at 12v means you're burning through 4AmpHours of battery in an hour (Derrrr! Corrected), so be careful of your useage.
scotjimland
2,375
10,327
A Woosh bang
4 amps at 12v means you're burning through 48AmpHours of battery in an hour, so about half of your average leisure battery.
sorry.. that is incorrect. you are confusing power (watts) with battery capacity (ah)
4amps at 12v = 48watt .. not 48ah ..
29
14
My set up is as follows,2x75ah batteries,300w MSW inverter,45w flat screen TV,100w mono panel,cheapo dual controller,I am a retired electrical engineer,I know people advise PSW to run TV's,but my MSW does the job, we are able to watch TV for 4 hrs nightly,by midday batteries are showing full, what's not to like about that!
Jun 18, 2012
317
531
Preston
Grandad's Camper-CPC
Since 2012
4 hours TV a night.;)
dutts303
dutts303
136
30
Devon
Chausson Flash 03
Since 2019
Thanks all for your replies. I remembered I had an old small inverter in my car (the all in one cigarette lighter plug to three pin 240v jobbie) and gave that a go with a small tv we have in our bedroom but found the inverter had a constant fan noise which was a bit annoying.
As we plan to do a bit of wild camping and not rely on EHU I think an inverter is in our future but will go for something a bit bigger and properly plumbed in like some of you suggest (probably with a solar panel).
Cheers again
Rich
Jan 8, 2013
8,493
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
It seems inverters are 85% efficient. So you use 15% more power at 240v. A 25w TV will consume 27.5w through the inverter.
