Hi All,
I have a Fiat Ducato Adria Twin. It's 2006 but before the next version.
I am trying to clean up the water tank having found lots of floating debris in it. I've emptied the tank and plan on using Puriclean but noticed a pipe going to the tank that was very mucky. I'd like a little help on identifying the purpose of the clear mucky tube. I originally though it was an overflow for when filling the tank, but now think it might be a breather tube? It looks like it goes off towards the filling point. I pushed some water down it using a separate pump and it appears to empty back into the water tank (along with the associated gunk).
So is it a breather or an overflow? If an overflow, why does it feed back into the tank? If a breather, why is it connected to the filling point. Does water go down it when I am filling up, as well as along the main pipe? (that would explain the gunk in my tank).
This picture is of the main filling pipe coming from the filling point. The clear tube goes up through the same hole in the side, and I can only assume is somehow connected to the outside filling point.
Any help appreciated. Also, anyone with the same tank.. do you know it's capacity?
