2002 FIAT DUCATO NIESMANN &amp BISCHOFF ARTO MOTORHOME HELP (1 Viewer)
Feb 20, 2021
24
7
Sunder
Hi I have. A 2002 FIAT DUCATO NIESMANN &amp BISCHOFF ARTO MOTORHOME looking for some advice please some one has stolen the electronic box from under the floor I need to replace it but I don’t know what it looks like or have a code for it any help out there photos or a code of your electric box any help welcome Thanks ken 07500611138
Jun 10, 2010
8,645
20,584
Shrewsbury (sometimes)
N&B Clou Liner MAN
It will be a CBE unit
I think nicholsong has the same model, maybe he can help?
Sep 20, 2015
255
494
Slovenia
N+B Arto 79R
since 2014
Have tried contacting N&B in Polch.
stefan.ternes@niesmann-bischoff.com
I have found Stefen very helpful and he speaks good english.
rob allen
Feb 20, 2021
24
7
Sunder
Thanks David I haven’t tried any where yet I’ve been at a loss till I found this site thanks again
Emmit
8,132
18,031
Cornwall
Pilote Explorateur
Jan.2014
Morning Rob rob allen ,
The advice you've been given here is but the tiniest tip of the biggest info. Iceberg that can be found on ALL aspects of motorhoming.
Before your next problem, (and by then you will have run out of 'free' posts) do yourself a favour, spend the best £15 you will ever spend and join Fun.
Oct 8, 2014
1,658
3,077
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
Hello, and :WelcomeFlag: from Wiltshire. Hope you get your problem sorted.
Jul 5, 2013
11,764
13,782
Since 2013
What did this electronic box do? Was it between the two floors or under the second one and open to the elements? I am surprised that anybody could get easy enough access to the Electrobloc, which should be between the the floors. Never heard of one being stolen before.
rob allen
Feb 20, 2021
24
7
Sunder
Hi peter the box went missing anywhere between Spain and UK as it was getting ship back companies we where dealing with are blaming each other an so on😡
Nov 26, 2014
1,517
6,761
Never on the wrong road ......
since 2014, before that 20 years of boating & caravanning
Could you post a photo of the area where the box is missing from,then we fellow N&B owners can maybe point you in the right direction.
rob allen
Feb 20, 2021
24
7
Sunder
rob allen
Feb 20, 2021
24
7
Sunder
Nov 26, 2014
1,517
6,761
Sorry Rob don’t see any similarities to my setup,the wires at the top with the white multi plugs look like 240 volt supplies and the large red and black are obviously 12volt leads an unusual mix unless it was a factory fitted invertor.What systems if any still work on the vans electrics, for example does the control panel function.
Nov 26, 2014
1,517
6,761
FYI Here’s images of my main electrical components.i have 2014 Arto76f<Broken link removed><Broken link removed>
Nov 26, 2014
1,517
6,761
Image 3 240v consumer unit and battery charger
image 1 12v distribution unit
image 2 control panel
funflair
19,600
31,447
Guisborough
MORELO palace
since 2012
I have a feeling that might not have been a standard Niesmann part especially with the UK 3 pin plug, does the main van panel switch on?
8,645
20,584
N&B Clou Liner MAN
Rob,
Just noticed on the classifieds you're after an EBL 4 so assume that's the one that's missing? Whilst I can't help with a replacement one, a friend of mine 'made' a replacement whilst his was being repaired. He put together a step by step guide if it is of any use as below.....
They re normally fitted with CBE not Elektroblock.
Form the wiring was it an inverter of some kind? I agree with martin the UK plug would suggest its not standard but then the white cables with Blue and Brown core is typical of N&B of that era. Are they marked?
Oct 12, 2009
10,884
24,101
A Class N+B Arto 69GL
Since 2009
Welcome.
I have a N&B 69GL (2003).
The probes you show a photo of are designed to detect water levels at 1/4 1/2 3/4 and full tank which is why on the guage above the door when one presses the LH switch to position 1 for fresh water tank the needle does not show percentage but only the nearest setting as I listed.
If you have still got the sensor rods out give them a good clean as getting furred up is usually the reason for them not working.
I have resorted to checking the level in the tank when filling or if we are nearly empty by unscrewing the 6" plastic inspection cover and dipping my hand/finger in.
Have you got a N&B manual for the Arto (in English)? You should find most things you need to know in there - well-written manuals.
Geoff
rob allen
Feb 20, 2021
24
7
Sunder
Hi Geoff thanks for you help do you no where I can get a manual it’s a 59b bought it at a sale last year fixing it up nearly dune but can’t the pump to kick in when it should once again thanks for your help
rob
