My E510 has the sameproblem and it is going into S&S Diesel Services tomorrow to find out what is causing the problem. Iwill report back.Thanks for your help, will have a look at the loom and see if I can get a part number.
Thanks John.
That's a bit of a conundrum then John ? I'm not at all familiar with Fiats but I would have though a mid range misfire might have been down to a sensor (crankshaft ?) problem and why does the pump have to come out if its the TVA that they think is faulty ?
The Peugeots are the same. Been going on for over 20 years & as you say should have been a recall & manufacturers to pay.Ours went into limp mode with injector loom problems, designed to short by fiat but never a recall, known falt
