2.2 to 2?5 conversion. (2 Viewers)
Jamesh
2,200
3,839
Van conversion
Caravaning since 2010
Anyone have any knowledge of converting a g9t 2.2 to 2.5 apparently they are the same block head etc different bore etc. But with same turbo ECU etc.
According to vauxhall owners club members it's possible. waiting to become a member.
I have had the van off the road for 3 months due to issues with the engine and garage covid etc.
Cheers James
17,655
43,513
It may very well be all the same, with the same model ECU, but likely running a different map in the software to account for different fueling and timing. If I was going to take on such a conversion, I would buy a complete donor vehicle, with matching ECU pump and other essential parts. Anything left over is then sold to cover some of the cost
Feb 15, 2014
714
1,250
cambridgeshire
Bessacar E450
3 years
Cheers James
I doubt the block would be the same internally, so might not be able to bore it enough for bigger pistons
Feb 15, 2014
714
1,250
cambridgeshire
Bessacar E450
3 years
looks like its bigger bore and longer stroke so you would need crank and rods as well, better to get a complete 2.5 and fit that I would have thought
J
Jamesh
2,200
3,839
Van conversion
I was thinking the whole engine.
Not including auxillary parts obviously but if I could get one with everything in place that would save me / garage time.
Cheers James
Feb 16, 2013
19,792
52,265
uttoxeter
ambulance conversion
50 years
I have a master with 2.5, which I'm afraid that's all I know about, and as far as I can tell it's a different gearbox and loads of other things, when I have looked for spares there isn't much that's the same.
J
Jamesh
2,200
3,839
Van conversion
Thanks I'll check with French auto specialist tomorrow.
Cheers James
Dec 24, 2014
9,280
47,882
Hurstpierpoint. Mid Sussex.
Compass Navigator
Presumably the 2.5 has a different state of tune otherwise it would be hardly worth increasing the capacity for the sake of just an extra 300cc........ or do have to replace the engine and you already have a 2.5 engine available? :unsure:
J
Jamesh
2,200
3,839
Van conversion
The reason is that the 2.2 is rare only 2 years approx and has issues which were sorted somewhat when they reverted to 2.5.
Finding another 2.2 will be hard as they are always being replaced n and the 2.5 is common.
Cheers James
J
Jamesh
2,200
3,839
Van conversion
Slight update the French specialist suggests that a crankshaft breather pipe us blocked and so that is forcing oil out of the seals - plausible??
Cheers James
Dec 24, 2014
9,280
47,882
Compass Navigator
Cheers James
Yes, that could happen, but you haven't actually said in any post what the problem is with the engine!
J
Jamesh
2,200
3,839
Van conversion
Hi sorry that's because I'm not actually sure!
Pushing out oil.
Renault specialist suggested it's possibly a breather pipe that's blocked.
It's in the garage do my hands are rather tied. He's going to hopefully try and sort it today...
I'm in Shipley north of Bradford.
Cheers James
Dec 24, 2014
9,280
47,882
Compass Navigator
Pushing out oil.
Where is the oil appearing? The oil filler cap? Somewhere at the side of the cylinder block? Underneath in the sump area?
J
Jamesh
2,200
3,839
Van conversion
Update I went to the garage and a week later they don't seem to be making any progress at all two engines in the floor.
I think they have lost interested in it.
What are my options?
Perhaps I should cut my losses??
Sell it as is...?
Cheers James
J
Jamesh
2,200
3,839
Van conversion
Update they have the. Engine in. But they cannot get it running due to the diesel pump fitted not in timing with the firing sequence? So diesel expert coming to sort Friday.....
Cheers James
17,655
43,513
I refer to my earlier post, the ECU needs a different map for the 2.5 compared to the 2.2
J
Jamesh
2,200
3,839
Van conversion
It's a 2.2 straight swap. So ECU same.
I was contemplating the 2.5 but they have been able to put the S/h 2.2 I got back in with new breather filter.
Fingers crossed!
Cheers James
43,396
49,927
Cheers James
Sounds to me like your first mistake, and a big one at that, was taking it to that garage.
If a trained mechanic can't set up timing for a diesel pump he must have got his certificate in a cornflake packet.
If it has an ECU and a common injector rail there is no sequence, its taken care of by the ECU.
J
Jamesh
2,200
3,839
Van conversion
I agree but hindsight is 20/20!
Hopefully it will be running by tomorrow night!!
Cheers James
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
Hope things turn out for you. As you don’t need extra stress In these times 🤞🤞🤞🤞🤞🍀🍀🍀
J
Jamesh
2,200
3,839
Van conversion
Went and picked up the van he says the engine is us?!!
It's running like a bag of nails!!
Running poorly, breathing via the oil cap.
will go back to my normal garage for a 2nd opinion.
Might start looking for a new van!
Cheers James
  • VID-20210430-WA0006.mp4
    6.1 MB
J
Jamesh
2,200
3,839
Van conversion
So update 4/5......
Took to garage as above ...
He agreed didn't sound good.
Noticed the wires are a mess in the fuse box. Also leaking oil.
Brakes were dodgy too.
He went to get it pre mot but they didn't finish it due to the oil.
However in the way home I took a longer route round the moor and thrashed it up to 50mph for about 10mins. This had the effect of getting rid of the bag of nails sound and the brakes were better v odd???
So I've got an oil leak from the crankcase seal I thing just above the power steering pump, wiring that needs a sort out, sounds more do able???
Also smells of mold in the back what the best way to get rid of it?
Cheers James
43,396
49,927
So update 4/5......
Cheers James
A match... :LOL:
J
Jamesh
2,200
3,839
Van conversion
3rd garage this morning who said it was a cam chain casting leak. They couldn't fix it.
Perhaps a loose chain had worn through the sky casting?
Looks like end if the road. Poor thing as it's running really quite well!
Cheers James
J
Jamesh
2,200
3,839
Van conversion
They said they had done as much as they could with it.
2 other garages won't touch it.
Thinking of trading in for a pug boxer etc.
Cheers James
